  • Replies 155
Exact same as R32.
Universal sensor, but the plug is same as R32.
If the plug isn't a direct fit, then the middle wire is signal, and the 2 outer wires are 12v for heating the sensor when cold (which you don't really need).
As long as your loom is from a DE, DET or 25DE the plug should be direct fit.
20E only uses a single wire sensor.
http://www.kudosmotorsports.com/catalog/ngk-ntk-lambda-sensor-oxygen-ntk-nissan-skyline-r32-gtst-gts4-gts25-rb20de-rb20det-rb25de-p-42.html
  • 5 weeks later...
  • 3 weeks later...
  • 1 month later...
Hey guys
nearing the end of finally getting my laurel finished and on the road, just wondering what i can use for a window washer bottle if i cant find a laurel one? and my windscreen wiper motor brother its little plastic ball joint, are all nissan ones universal?
And same with overflow or should i just get any random nissan overflow and make a bracket to hold it?
hey guys im new on this site and recently bought a rb20det ceff anyway long story short i have come to the conclusion that my igniter pack(part number:2202058s01) (black box that sits on rockercover) has shat itself. is there anyother igniters that will work on this car (not phased about having to change plugs thats no issue and if so possible places i can find them? thanks guys
Cefiros come with both series 1 and 2 RB20s.
The square shaped plug on the ignitor module is series 1, series 2 has a same sized plug but the shape is a bit more round on the corners.
Hit any local Jap parts wrecker and they'll be able to sort you out.
Generally, S1 RB20s are found in R31s, S2 in R32s.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
