I know its been spoken many times before, But I havent seen any referance to this.. so thought you might like to have a little look and comment on if you think it would work,
it says stagea there...
http://translate.google.com.au/translate?hl=en&sl=ja&u=http://www.rakuten.ne.jp/gold/naniwaya/bosr/option/option_cancelar.htm
been finding heeps of goodies recently on the net, like eyelids and such..
https://www.sau.com.au/forums/topic/358286-airbag-light/
dont quote me, but if the system finds a fault, no airbag will deploy in the event of an accident.
therefore, no error lights will deploy the required airbag (assuming you have one connected).
so putting the resistor in the place of the airbag will stop the fault code and the system will act 'normally'
https://www.sau.com.au/forums/topic/358286-airbag-light/#findComment-5724967
That would be my understanding also; obviously if theres no sensors other than the ones in the seat - then the bags will never go off if you've put a resistor in its place.
https://www.sau.com.au/forums/topic/358286-airbag-light/#findComment-5725002
i dont think there is a sensor in the seat
its a ram that tilts the seat backwards........ i think
for people with the safetly pack, there are bags in the ouside edge of the seat too.
I've got one sitting on my desk at home, I havent the foggiest idea how it operates - I assumed it was a sensor of some description (the warning on it is DO NOT DROP so I figured it worked as G/shock Sensor), but it could well tilt the seat in the event of a crash. I'll take some photos of it tonight
https://www.sau.com.au/forums/topic/358286-airbag-light/#findComment-5725058
Here's my understanding of this after lots of research & trying various "solutions".
The ram/s under the seats are to stop submarining in the event of an accident. They could tilt the seat as Iain suggested or, as I'm led to believe, push the front foam cushion up under your thighs to stop you sliding forward into the footwell. Same result in the end. I can't actually tell physically where they live under the seat since mine are gone & I just have the yellow connectors swinging in the breeze.
The fix that has worked on some cars (notably GTRs) was for a 2.2 ohm resistor, but this thread http://www.skylinesaustralia.com/forums/St...ht-t340591.html shows guys going for this u-turn harness http://gt-rr.com/pro..._harness&id=761.
I actually bought these ones http://www.tunersgro...rn_harness.html for my M35. They even took exact details of my car to make sure of compatibility.
The interesting thing is they don't show up any resistance when measured with a mutimeter......
The result? Nothing worked in my case :mad: , but I would be happy to send the Works Bell u-turn harnesses to anyone who wishes to try them out.
I'm still waiting on a spare SRS module from some guy with a wrecked one, just to see if my problem is bigger than the harness can fix.
https://www.sau.com.au/forums/topic/358286-airbag-light/#findComment-5725111
i think you mean you plugged it in :P
on my electric seats, there is a clip holding the yellow plug into the back of the ram. looks like it can pop off easily. pull your seats out guys, might be a simple fix like above!!
https://www.sau.com.au/forums/topic/358286-airbag-light/#findComment-5727299
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
