Disclaimer: I do not have this car yet, I may not even buy this car, but there's a good chance that I will. Plus I'm bored and building "fantasy" cars is always fun.
Here's the scenario. I've been saving for a while now to get my turbo car when I come off my P's in 12 months. I had originally meant to get an S15 or an R34 GTT for around $20,000. However at the latest DECA I took a good look at a couple of mental 180SXs and was convinced to buy one.
My plans for this car is for it to be my daily driver for a short while, track it occasionally, and goto DECA 4x a year. However once I have a steady income I can easily see myself getting a second practical daily and turning this into a track dedicated car.
So considering I had $20,000 to begin with and I plan on buying a decent 180sx for half that. I still have $10,000 to spend on goodies. Assume the car is stock, what would you do?
Things I definitely want are:
2-way LSD
Coilovers - how much should I spend on these? $1,000 cheapies or go for a nicer set?
Racing seat.
Otherwise what else should I spend the $$ on?
Brake upgrade
Clutch
Half cage (they're street legal, correct?)
ECU, exhaust, intercooler, tune
Swaybars
Tyres
Decent rims
Turbo upgrade
E85?
I dunno, there's so much you can do. I'm just wondering what the wisest choice and order is to go about these things.
https://www.sau.com.au/forums/topic/358460-help-me-build-my-180sx/
Probably buy a car already built with aftermarket goodies, save a lot of time + money. Wish i did :(
I thought about that, but my main concern is that any heavily modified 180sx, particularly if they're sporting a 2-way diff, cage or the like is its probably been drifted. I don't mean around the streets I mean out on the track given the thrashing of a lifetime.
There are some nice 180s floating around power mods, which I might look at, but if I wanted to go the full haul I'd buy an unregistered drift pig with the works done to it and save my money for spare parts.
Dude you get off your P's in 1 year. Who knows what will change then.
Unless you plan on building the car on your own and you really care about it... then from what I've been told its better to buy one with mods. Obviously not a cage, but just the usual power mods.
http://nissansilvia.com/ is a good place to start as there's more info on SR20's there...
How much you should spend and on what depends on what YOU want the car to do.
If it was me I'd buy one already modded and not touch it, if you're just driving on the street you don't need that much power.
So whats the cost of a second hand engine compared to all the goodies hanging off a pre-built car? I'll tell you, it's a lot of time and money. Unless as stated you were looking to get your hands dirty + know some people who can help with stuff (cheap parts, cheap tuning, etc).
Look either way, TAKE YOUR TIME and at least get it checked over by a mechanic you trust who knows these types of cars or at least RAA, etc with compression test and anything else they can check. :thumbsup:
GL
Our SIL80 had
Intercooler
Rocker Arm Stoppers
Boost Controller
Adaptronic E420C ECU (So cheap and great on 4cyl cars)
3 inch turbo back exhaust
Coil overs
1.5 way diff
HD clutch
We had a built 14 motor for it but you wouldnt need to do that
It was awesome fun like that and the whole thing cost us just under 7k (body was a shitter)
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
