  • Replies 804
Ahk, previous owner did the conversion on my car and I got pinged at the pits for the crossmember not bolting up to all 4 holes. It sounds pretty picky but I'd like to fix it anyway regardless of the defect. Just learning now about all the RB crossmembers (A, B and C) and S13 crossmembers as well (also A, B and C).
I have done some research and looks like most people say an SR20 manual crossmember (labeled 'C') fits.
I think when my conversion was done the auto crossmember was used and had flat bar welded to it so all 4 bolts were used
Pretty much what I did for the 25 box conversion but the other way. Used 5mm flatbar to extend the RB20 manual Xmember to pick up all 4 bolts holes (25 box mounts are further back)
Yeah fabricating something to fit is the best bet but I can't weld and don't have any time to take it anywhere haha. I think I'm going to get an S13 one this afternoon and see if it fits.
I haven't quite got my head around it all... I'm not sure if there's A, B and C mounts for EACH car (Skyline and Silvia) or just those 3 mounts that universally are used on both chassis.
Here's a pic (all are facing the same way), seems like I need the top mount.
Sorry to hijack the 32 thread with completely confusing and boring content.
I have the middle one but it sits too far forward. The bottom one is a custom one.
I will go out on a limb and say you have an R32 GTSt MANUAL Xmember.. I had to extend my holes with flatbar because the mounts on the 25t box are 50mm further back than the 20t box.
If it *looked* strong enough I don't see why not..
75PFC with 5mm flatbar extensions for the holes a gusset on each leg and decent welding (read: not dodgy looking) should be fine if you wanted to make one from scratch.
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
