im not saying that my current set up would munch scotts old setup. but the results in jethro's car as to when they were in scotts car are pretty different - maybe because the dyno has been re calibrated - but scott was making over 1100nm. where as(correct me if im wrong jethro) Jethros making about 750-800nm. i guess the next time your in melb i have to take you for a spin.
Could be because he had it up to 20+ PSI?
Also I have no actuator mod or EBC....>_<
And god knows what other mods he had!!
  • Replies 70
Posted Images
You have his system lol.......those two things mentioned above are the differences....In fact you should do better as you has a better FMIC!
P.S. Aaron the next time I am down there hopefully I will have the new GB with shift kit and my other secret weapon doneninja.gif so above 300AWKW's on BP98 with the standard housing on 18-19PSI is coming soon to a dyno near you!!!!....btw a not so scary setup would be to put some decent bloody tyres on it!....your will loose the fun factor though but acceleration will be up!
Edited by Jetwreck
So if I put an EBC in I should get the same result Scotty got?
hmmmmmmmmmmmmmmmmmmmm :ninja:
should be slightly better up top.....down low will should have a little more lag because you have a different bigger FMIC......and of cause there's the exception of how his stall converter worked down low as well.
fuarrrrk you guys are nuts. im just happy with my stock boost. lol i dont even have a boost gauge in the car (will sort that out soon)
i mean as cool as it would be a big ass stagea ripping cars on the street. its a big ass wagon.. and awd.
im just keeping mine as a daily. lol you guys need to buy dedicated track cars that you can thrash on sundays to keep the balance of cruising/racing
lol....nut's I amwacko.gif....already have a dedicated track car in the family + I drive for someone!
P
Lol I agree to a certain extent...but our cars are heavy...stock form it didn't seem that fast!
+1
it still doesnt seem that fast :ph34r: put a our engine in another car(much lighter) i think there would be an insane difference on how it feels.
the (not so)new v35s shouldve come in a vq25det option as well.
skyline 250GT-T lol
skyline 250GT-T lol
someone needs to get manual happening on this shit right away,. THEN ill think its all worth it!
http://www.skylinesaustralia.com/forums/topic/358412-z32-300zx-with-vq30-twin-turbo-conversion/
http://www.nismo.com.au/Page_12.htm
Not exactly the same but, yeah...
Edited by Daleo
RWD is easy, AWD is a little harder. I need sponsors like that team. :)
They used a 300zx box as someone has made an adapter for that already. I'm waiting for the R34 gtr Getrag conversion kit...
I like the trigger on the crank pulley, that would allow any ecu to be used.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
