As the title says, I'm dishing out a total of $1000 for a new audio system in my R34 Non-turbo Coupe. This is a part I want in it, a Pioneer DEH-8350SD headunit, replace all the speakers in my car with new ones and finally install a new subwoofer (doesn't need to be massive). All this will be installed by a professional.
What speakers and subwoofer fit into the price range of my budget?
Is the Pioneer DEH-8350SD able to control iPhone 4 in the actual headunit itself or do I have to use my iPhone to change the music?
How much is fitting and are there any suggestions for who can do it in Victoria? Or should I just go to Autobarn?
Finally, if I want to buy a new car, can I remove these parts and replace them with my stock parts and transfer the new parts to my new car? (Thinking of changing to a turbo in 3 years time)
Any suggestions / help appreciated!
Thanks!
https://www.sau.com.au/forums/topic/358953-1000-sound-system/
I don't understand.. your other thread you stated a mere 8 days ago that you have spent all your money and couldnt afford the 2k for the aus replacement of your equipment.. Now you have 1k already.. maybe wait another 8 days and you can make your car look factory and work awesome..
Well $2000 is too much for me to spend, I work two part time jobs and I really don't want to spend that much on an N/A car as I'll be upgrading to a turbo in three years time. I guess screw the speakers and subwoofer then, I'll just get the headunit so I can actually play SOMETHING in my car -_-
Ok Grey,
i'm not joining on the flaming, but Beast is right, keep saving, "Do it right the first time" don't waste money fiddeling at the back and setteling for peices of shit as you will Need to replace them in the future, and the money you already spent will be for nothing.
Secondly, to get a Sub to work you need an amp, a Good one at the least will cost $300+ , it doesn't sound important but it's probally the difference between a GTR and a N/A in the audio world.
Keep Saving and maybe for the time being sound GHEY and stupid but maybe an ipod, and a dock if you have one?,,,
Justin (JPN-893)
I managed to get a full sony sound system for 1k, came with headunit (ipod compatable and USB dock), 6.5 splits, 6x9 3 ways. 12" sub in box and mono amp. and wiring kit. i got it threw wow sight and sound (not avalable in southen states to my knowlage). but if you look around, say autobarn, jb hifi, stafild. you might come accross a complet package for something close to your budget. and installing isn't hard. theri should be a few threads in the DIY/ fab sections on how to install radio gear. Just rember to keep your old stuff for when you wona change back.
It wouldn't be that hard if his car had provision for a DIN headunit. In another of his threads, it's established that he has the model with the different climate control unit, and the pop-up screen option - which means he's going to need to source the appropriate parts to convert it to a regular double-din slot & the regular climate control unit before doing anything:
http://www.skylinesaustralia.com/forums/topic/357549-r34-head-unit/page__view__findpost__p__5715247
All of this means that he's unlikely to get what he wants for $1000 or less - especially if he needs someone else to do all the work.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
