Hi guys.
This is a sad topic to post and a very self-indulgent one at that, but the time has come, after 6 long and wonderful years, to let her go.
it's a decision I've been agonising over for the past month since getting a new car but I just.can't.justify.having.2.cars.
seriously sucks, but whoever gets her, I hope she's treated well.
mods, I've been away for a while from the forums and as such, am unaware of the rules about posting in the NSW section and linking to stuff, but this is more of a lament than a for sale thread.
See you guys at a Pizza cruise.. (when's the next one anyway, Marsss?)
She's leaving me :'(
https://www.sau.com.au/forums/topic/359040-squish-is-for-sale/
  • 3 weeks later...
this is a trend, chubbz
but unfortunately, there's too much other stuff I want to spend moneys on.
and I just bought a new car too...
having said that, I'm not in any rush to sell her... the sound out of the 3.5" makes me tweak in the pants....
good luck mate, clicked the link and did a doubletake as its pretty much MY car but with different rims.
let us know how it goes, whats the new ride?
bit jelly as i would love to upgrade to a 34 but moneys is hard to come by lately for some reason :(
i think even if i won the lotto it would be hard to say goodbye to the 33, so many memories..
You better not be replacing it with that ghey boxter you were cruising around Kings Cross in you big queer.
yeah, i don't think you have it in you, marsssssss
Must be in YOU then lizzard..
Yea Marsss you must be losing it in your old age... :P
Not what yo mama said...
Nah ghey Evo or some such shit...
Impuls won't fit
Pizza people.. PIZZA...SAT 14th anyone??
  • 1 month later...
Nick, it was a damn carrera, ffs :)
Car is sold... I am actually in the process of grieving. That car has been a massive part of my life for the last 6.5 years.
Went to a good home. the guy that bought it had some issues with the button clutch though, lol. He will restore it to its former glory. At the end of the innings it had some cosmetic issues but she was a joy to throw around.
AWD is just not as much fun round the bends and some folks that may have a long memory know I loove oversteer.
On another note, get to play with a 360modena this weekend. Taking it up the old pac tomorrow. Can't wait!
I'll be at the rest stop at Mooney Mooney/Brooklyn at around 10:30 so I better see skidz
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
