For sale is
1 factory aero front bar for gtt
1 standard rear bar for gtt
Rear bar is in great condition, front bar has been slightly trimmed for intercooler clearance. Both are in undercoat.
Price 300 ono for both
1 z tune style r34 GTT carbon fibre bonnet
Brand new never fitted but has been taken out
Of box. Extremely well made,. Price is 670 ono
0422198643
Located on essendon vic
dimension and weight of the bonnet pls? postage is a bitch so i gotta check it out first..
hey bud front bar is plastic (oem nissan) same is rear bar. would prefer to sell together
take them both for 250
would you be able to supply and deliver to NSW 2519 for the front bar? Would prefer to get an OEM one in factory Silver, but if the price is right would consider buying and painting. Reply by PM please :)
  • 1 month later...
  • 4 weeks later...
Hey mate interested in your rear bar.
Is it an actual original or a copy??
Does it come with the skyline letters and the gtt sticker thing?
How much do you think it would cost to paint silver??
And can you post to Wollongong (nsw south coast)
  • 2 years later...
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
