  • 3 weeks later...
  • Replies 200
Ok guys, this is getting closer! Would like to get some confirmations and payments in to confirm that this event will go ahead!
I will have the complete prize list and categories posted very soon.
The current list of attendees from our side:
1.CeJay(to pay)
2. Kat
3.Pat
4. Luke
5.James
Surely we have more takers, this was a really fun day last year!
Supra boys, how is this going from your side?
I'll aim to be there and pay on the day assuming there are spots left. Will be up at the drag day http://www.skylinesaustralia.com/forums/topic/364933-s-a-u-n-s-w-private-wsid-drag-racing-day/page__p__5822470#entry5822470 the day before.
im thinking of taking the rover.
maybe a comp for whoever guesses the correct 4wkw - winner get a happy meal.
specs -93 model, 3.5l V8 efi petrol, awd, auto, black bonnet, worn front tyres.
my guess is 43.2kw @ all 4
nb* if its a hot chic, im the happy meal...
It's open for all! The more the merrier. Would like to start seeing some spots get filled :D
Would also like to add that the entry cost is now $50 for ALL entrants.
Start signing up peoples! And spread the word to your friends! Lets get some fun cars here!
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
