  • Replies 200
So I take it that this is no longer really a Skyline Vs Supra thing? I'm just wondering if Skylines and Supras will be out numbered by other kinds of cars? Perhaps we should change the offical name of the event to something a little more fitting? I'm just thinking about the magazine writer/photographer. It wouild be a bit strange to have the title "Skyline vs Supra Dyno Day ACT" (or similar) only to have the article read that there were only 6 Skylines and 2 Supras in a field of 30 cars! I think it would just say to all the readers that there is no import/jap scene in Canberra or that the 2 respective groups are lazy and aren't interested in club events.
Thoughts? Am I thinking about this too much?
Maybe something like "Nissan vs Toyota" or "ACT Import Dyno Day" or "Canberra JDM Dyno Shootout"? I dunno. I just don't want it to reflect poorly on either the 2 main car clubs involved or the organisers.
Anyway, can't wait for Sunday!
Edited by Frink
Sorry, I didn't realise it wasn't changed on here, but yes, it is more of a Toyota v Nissan type deal now due to the lack of numbers.
Categories for prizes are the same as last year but this time participants will vote for the car for that prize and you cannot vote for the same car twice. This way everyone has a shot of winning something.
Bring a chair as we don't have access to chairs like last year.
I'm not too fussed as to how/what this event reflects on me as this is the last time I'm organising something like this. If you don't enjoy yourself then feel free to blame it on me...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
