http://www.skylinesaustralia.com/forums/topic/358412-z32-300zx-with-vq30-twin-turbo-conversion/
This is a link to the UAS 300zx with its new VQ engine. JP has gone through a lot of development and changes to this car over the years. Lots of aero bits, new guards, diffusers suspension angle changes.
The new VQ is much lighter than the old VG and it currently has a pretty neat high rear mounted turbo set up behind the strut towers.
Anyway click the link and see what you think.
Nice find, I popped this up a week or so ago, http://www.skylinesaustralia.com/forums/topic/358634-which-turbo-for-vq25-det/page__st__20__p__5731176__fromsearch__1#entry5731176
There is some amazing development work on this car :thumbsup:
Edited by Daleo
  • 4 months later...
I heard they had an engine failure? If so, it's a shame for them, but for a stock bottom end, they'd have to be pretty impressed.
Good excuse to rebuild it and push harder?
Yeah they did late in the 2nd day of comp. It was amazing to hear. From what I saw there was a fire. Very small but ended its day. Wasnt the fastest pro car there but good to see aussie built cars in the pro class
from Dave
"busted the top of a sleeve in the vq30. (epic head gasket failure) over heated) these things are pretty tough. stock rods are scary thin and use 7mm thick rod bolts. reving to 8k and over 9k on down changes with 20 pounds boost, pulled from a halfcut.. (with our bolt ons lol) bearings all like new as are pistons.
bigger and better here we come :) "
these engines are very good and uber easy to work on. the problem is the rear thermostats that regulate coolant flow thru the block. the later vq's did away with it. the problem is once the coolant gets over 100 degrees they open and bypass the water away from the heads, which is low to begin with. ..... ghay design. but very easily fixed with aftermarket head gaskets that mimic the vq35hr design. or vq35hr gaskets at a whopping 30 bucks each...lol.
At least you can solve the issue; gonna need new gaskets for a build anyway; don't imagine you'd be using a stocker for stage 2?
  • 3 weeks later...
Custom quick release offset rack ends to adjust bump steer and Akerman angle.
Custom solid mounted alloy rack bushes replacing flexing urethane items.
Adjustable hollow sway bar.
After busting a head gasket at Superlap on the stock motor and finding it's limit, we are now bulding a tuff motor and increasing to 3.5 litre. We are using a Darton Sleave kit (closed deck) using different head gaskets which are much better and have a sealing rings. This requires modifying the engines coolant flow and does away with the two rear thermostats,not good for racing. We are using a VQ35 crank, forged rods and pistons. Whilst at it we have slightly ported and then polished the ports and domes. We relieved the domes to match the 95.5mm pistons up from 93mm. Also adding ARP main studs. We are also upgrading the turbos to either GT2871's or 3071's.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
