  • Replies 77
Posted Images
Don't know what the Stagea one is like to install, but obviously it would be different. Just as the Silvia one is different.
The Walbro is a lot easier to install than the Bosch that is for sure. Definetely not as easy as the Tomei/Nismo one given that you literally pull the entire old fuel pump assembely out of the fuel tank and put the new unit in and plug it back in and you are done.
The Walbros are a lot more sensitive to flow rates vs voltage and therefore some cars require rewiring to ensure they get 14V.
As I said, if you are confident in what you are doing get the cheaper fuel pump. I am just saying the Tomei/Nismo is worth the money given how reliable and easy the install is.
Your choice.
Heard about the rewiring a lot, from where to where do I need to rewire - sounds like another pain in the a.. I think the walbros come with the short bits of wiring from pump to top of assemply plastic cylinder thingy.. Not keen on rewiring other bits of the car mate!
Everyone I know with a walbro pump just says they would not get one again..... I dont have any experience with them so can't really say they are bad, but going off what others have said I wouldnt buy one
They are not purely for a drag/high power setup. I have run one for nearly 3 years, from when the car was basically stock just before I got a tune till now, and I cannot fault the Tomei pump at all. It is near silent, has never had fuel supply issues, and only took about half an hour to install
Bosch pumps are noisey and have pickup issues
Walbro, from what I know, need a direct power feed because they only provide there rated fuel supply at 15v or something?
Like I said I dont have experience with these two, but just saying that I've never regretted paying a little bit extra for the tomei pump
Anyone else think I need a new fuel pump?? Now I'm confused on whether I need a Bosch 044 or 040..
i dont think you need a fuel pump, i KNOW you need a fuel pump.
a 10+ year old fuel pump is just asking for trouble when you are giving it stick, especially if you have modified the car
just reading the Nissan Silvia forums, everyones recommending the walbro over the bosch
of course they are :rolleyes:
For this guys power goals the walbro will be fine and wont require rewiring, I had one in my old gtst (270kw) and know plenty of ppl that have had them and had no trouble running them for several years with decent power. My best mate runs one in his 240kw evo 8 mr and has no troubles at all. As stated pay the 10 bucks extra and get the one from a vendor with the correct fitting kit so you know its genuine. There are plenty of DIY out there for fitting these fuel pumps and if your unsure ask someone thats done one or take it to your mechanic.
As for the nismo/tomei..whats the point in paying $600 odd for a fuel pump when his only going to be pumping out about 200odd rwkw...if he said 300kw i could see the point, The walbro/bosch will certainly be enough for his power. There a piece of piss to fit if you have half a braincell on mechanics or can follow one of the DIY threads.
Cheers Dan, my ultimate goal is 300rwkw - thats when I get the remaining 3 items - injectors, turbo and Z32, keep telling myself I wont waste money on these, but knowing myself, I know I will, lol..! ! So I guess the Walbro is not so bad - GAS Motorsport in Wetherill Park sell them (Walbro GSS342) for $115 -I guess thats a good price for a decent item. So it WILL support 300rwkw wont it?
And you said it for me - dont see the point in spending $600 odd for a bloody fuel pump, should be ok to fit - I did my FMIC, spark plugs, oil change and oil + fuel filters myself. Read the DIY on the Bosch 040 - seems the hard bit is putting the assembly properly back down the tank in the correct position in slot..
And Hamish, what does a 325rwkw GTS-T FEEL like on the road - compared to a baby 200rwkw?? Shits on pretty much everything? Hows the response from jab on the throttle etc..
a LOT faster ;)
I had a Walbro running 200awkw. Rewired it to full battery voltage (at least two DIY threads in here or pay someone to do it) and ran 245awkw but now upgrading for RB30. If I were you and you want 300kw down the line get a better pump now and be done with it - such as this Denso:
http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Performance/Fuel-systems/auction-365629302.htm
ok ok so do the Bosch 040s require re-wiring as well like the Walbros, once u go over a certain power level/flow rate... faark so hard to decide ha ha.. 280-300rwkw max goal - no nismo or tomeis please, just one simple reasonable quality internal pump....
I use the Walbro, put the stock sock on the bottom of it for better fuel pickup.
I'm running 290rwkw on E_Flex (E70, so 25% more fuel needed than with PULP98) with perfect AFR's before doing the direct battery wiring, but since then have done the direct battery wiring for peice of mind.
there's a lot of walbro hate round here. But for me it seems to be working a treat!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
