  • Replies 482
Hi guys I'm looking at getting a manual stagea but i am yet to see one anywhere in perth. Just want to have a chat to anyone with a manual stagea.
Cheers
What do you wanna know?
There are a couple of RS4Ss I know of in Perth.
I bought mine from NSW (none for sale in WA at the time) about 9 months ago.
I just wanted to know what the difference is with the power delivery and the fuel economy from auto to manual. I'm looking to import a 260 but if I could find a manual rs4 that would be great. If anybody would be keen to meet up with me and have a chat that would be good
Cheers
Cheers
I didn't actually ever drive an auto, probably a bit dumb but after driving my slusho sh*tbox Cressida for 2 years I had enough of torque converters and slippage.
Did you have any problems getting road worthy certs because the car was from over east
I drove around on NSW plates for a month or so.
I got knocked back because some numpty had put blue globes in my indicators, my castor rod bushes were blown out and my rear tyres just touched my rear struts on full bump (another long story).
All of the above were legit issues in my eyes though so it was fair.
A full (expensive) day of getting shiz sorted and it was all sweet.
They didn't look twice at the exhaust or coilovers.
Cheers
where abouts in perth are u?
Ok my auto is lucky to get 350. I know my fuel filler is not sealing right as can smell fuel some times. Have tryed fixing it but still smell it. Also I have trouble with the start up first thing in the morning its kinda like it not have full presser to the injectors but not worked it out yet
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
