shit..
im making 20psi by ~5000rpm..
thats with e85, poncams and stempipe manifold
Wtf??? That's shit as. Way too late for a 3076. I got a stock ported manifold and stock cams (have a cam gear only) and is internally gated.
Just looked at your boost line and looks lazy. What controller you using? Or just off the external gate
  • Replies 55
Posted Images
Hi there,
From what you write about your high-flowed turbo I would buy immediately buy it, since it sounds like lots
of low down grunt and fun :) Who made this unit???
I have this nice boost controller, it has 3 settings .. 'off' 'low' 'high' ... wouldn't that help to tame the unit?
Anyhow, the car is used as anything from grocery getter to daily driver (though not as a commuter)
From time to time for the drag strip, but not on a 'professional basis'
My insurance policy states 'recreational use' and that's the truth ..
I wouldn't want too much downtime with the turbo upgrade, and I have a good mechanic at hand who
does very good work (but only at weekends)
Here in the UK there's is quite some backfround noise with High Flowed Turbos, usually you get no 'hard data' on these.
'They' just state 'stage1' or 'stage2' and that's something I wouldn't buy especially when being quite pricy...
I had a recommendation for a HKS28xx kit .. but that was very pricey ...
Cheers from London,
Andrew
I had a hiflow at 250rwkw and it was sometimes pretty hard to drive. Made heaps of boost and came on hard way too early in the rev range. On wet days if you tried to accelerate in 4th from say 70 to 100km/h you'd get wheel spin all the time. Fun but a real PITA, you couldn't always count on controlling it. Not saying all hiflows are like this, but mine was.
Stopping at uphill sets of traffic lights on wet days - just thinking about it used to make me break out in cold sweats. I'd plan my route to avoid having to go through them.
I went to a 3076 with external gate and WMI at 300rwkw and its a totally better vehicle all round. Good reliable steady progressive power. Transformed the car, made it a damn sight easier to live with. So its not called lag, its called control to me!!!
But buying and installing such a turbo takes more effort and $$$$ than one that bolts up to the std dumps etc. It really depends on your end goals and what you want to do with the car long term. Also - if you buy say a hypergear hiflow as an interim step - how easy would it be to resell later and get your $$$ back when you decide to up size??? Simple things like this can help make your build more progressive and easier on the bank account.
Edited by Torques
Too much boost early in the rev range. WTF? Never heard that before. You should drive a 6L Supercharged V8. That's low down power. You need to learn some right foot control. Throttle isn't an on/off switch.
Hi there,
I still would like to know who made this high flowed unit???
Cheers from London :)
It was hiflowed by GCG in Sydney, not sure if it was a completely std turbo to start with, it came on the car. From memory it went from 50/7? to 56/76 but I could be wrong there, I gave all the paperwork to the person who bought it off me. I also had other mods that allowed the 250rwkw to be made [fmic, pfc, tomei cams, dump, exhaust, hiflow cat, z32, etc etc]. But as I said I didn't like its power delivery, was not as progressive.
The 3076 makes 50kw more power but has a much better power delivery and more of it [in the rev range] where you need it.
If I was you I'd send Stao from Hypergear a PM and get one of his units, only ever heard good things about his product.
Yeah ... I will send him a PM, he seems to have lots of experience and also documents his results well.
There's an inner voice that says 'go high mount, go high mount'. ;) But that would involve too much downtime (but would be quite sexy)
Many thanks ...
Edited by Torques
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
