Well we were the only girls there but it was a totally awesome day.Thank you waxit guys for washing my filthy skyline and allso a lovely lunch.It was really nice to meet all you guys,soon as i got back to my motel i cleaned my rear bar and zorst tips your cleaners are amazing so easy to put on and take off no hard work at all.Look forward to seeing you all again Genelle. :cheers:
https://www.sau.com.au/forums/topic/360187-detailing-day/#findComment-5764838
Fantastic day, really glad I went, and learnt heaps from a well-run workshop that covered a lot. Weather held up beautifully too. Great to meet Antonio and Russel from Waxit, as well as see a few familiar SAU faces. The black 34 GTR was mint. Love your 19" volks.
My wallet's a lot lighter with all the stuff I bought, but it'll be an investment in my poor neglected car. Really amazed at how that special cleaner just powered through all the buildup on the rear-bar from the exhaust. I've tried removing it before with many things, none of which worked. I shelled out for the C.Quartz hard coat that apparently lasts for >12 months. I'm lazy, and can't be assed waxing every 2 months. Anyone else used this? I think you have to be quite particular and fussy with how to apply it - it is not as forgiving as wax/other sealantsm, and the surface you are coating really should be pristine. Will give it a go later.
Looking forward to the advanced session.
https://www.sau.com.au/forums/topic/360187-detailing-day/#findComment-5764975
definateiy not your stereotypical skyline owner, until you spoke up i was trying to figure out whos mum you were :laugh:
Ha ha,i have a few grandsons they all love cruiseing in the skyline,they all call me skyline nan. :D
https://www.sau.com.au/forums/topic/360187-detailing-day/#findComment-5764999
:worship: "Skyline Nan"... ...That's awesome...
It was great to see you there... ...And I'm glad you enjoyed yourself... ...I'll make special mention of you coming down in SAU Vic TV and I hope you don't mind you car being in an episode...
https://www.sau.com.au/forums/topic/360187-detailing-day/#findComment-5765034
was an awesome day! cant wait for the advanced day!
it really was amazing to see just how easy high quality products are to use. I am planning to take my car down to the guys in a couple of weeks to get the bonnet looked at and will definately shell out for the p21 kit and the wheel sealant
https://www.sau.com.au/forums/topic/360187-detailing-day/#findComment-5765259
No worries,there were some very nice imports,think my fave was the black beauty. :banana:
https://www.sau.com.au/forums/topic/360187-detailing-day/#findComment-5765439
Big thanks to Waxit and Antonio for taking the time to show us how to maintain our cars in the correct way, thanks for all the comments about my GTR as well, its good to see the hours of me being pedantic about it pays off!!! I like many others, emptied my pockets again in the showroom, there is just so much I wanted and had to have!!!
I'll be in for the next one...
https://www.sau.com.au/forums/topic/360187-detailing-day/#findComment-5765529
Hi Guys and Gals,
Thanks again for coming down to the Waxit SAU Detailing Clinic,
Great to meet you all, and Im wrapped we found a way to clean the black stuff from around the rear bar from your exhausts.
If anyone has any questions please shout out!
See you all soon!
https://www.sau.com.au/forums/topic/360187-detailing-day/#findComment-5765557
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
