Hey guys,
ive have a Apexi Afc neo lying around the house that used to be used in my soarer, question i have is it worthwhile installing into the GTR? is it even possible as the rb26 runs 2 afms?
my car is relatively stock (turbo back exhaust) and don't plan on major mods, so i don't justify shaking out a $1k for a PFC.
not looking for major power gains just a bit more response/torque maybe some economy on the way.
any input would be great?
https://www.sau.com.au/forums/topic/360213-apexi-afc-neo/
Waste of tiime imo...
To me the gtr ecu is lean as is until very high up in the rev range so economy is probably as good as it gets with no direct control over timing, and timing is where its at if you want more response/torque..
Remember the afc affects fueling by altering the air flow signal and it changes timing indirectly....most times opposite of where you would want it to be so its a balancing act and gains if any would be minimal
Its works ok for the 25det guys with minor mods trying to get rid of r&r but on the 26 its basically worthless
With that said i have a safc2 on my 26 along side a pfc but its sole purpose is to act as a 2nd knock dectecting device...a feature the neo doesnt have
So unless if you just want a pretty colourful screen on your dash ditch it and get a pfc
https://www.sau.com.au/forums/topic/360213-apexi-afc-neo/#findComment-5752399
sif, nistune supplied fitted and tuned for under 1k, power fc 1k to buy then tuning :)
You'd need to get 32 GTR ECU on top of that.
Unless there's Nistune board for 33 GTR available?
https://www.sau.com.au/forums/topic/360213-apexi-afc-neo/#findComment-5752964
Hey guys,
If any of your mates have a wideband, hook it up to your rear exhaust take it for a ride, if the A/F are decent don't bother with anything. Just enjoy the car the way it is.
https://www.sau.com.au/forums/topic/360213-apexi-afc-neo/#findComment-5754142
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
