I am told that the new hiflowed turbo they do for around $1800 is equivelant to a GT3040
See the posts by B-man, he had a GCG rebuilt turbo that was meant to be a rough generic equiv to a 3040. It made great power up to 250rwks with a wack of boost...but then bolted on a HKS (ok so different to Garret but...) and got an extra 50-75rwks, so i dont think it is really an equivelant.
Good power, but 3040 power maybe falls a bit short... check B-mans posts
What sort of boost response would the 450 HP highflow have on an RB20DET?
I dont have a stage 1 but i have a stage two on RB20 with no tuning so you can atleast get an indication.
Mine starts to gradually build boost from about 3k, has 5psi by 4k, hits 7 by 4200 and then rockets to 11psi (i haven't upgraded fuel yet so am pegging it there at the moment) I have exhaust, cooler and pod.
It's a fair bet that the stage 1 will make good boost slightly earlier than this and the boost response will be less peaky.
Guest INASNT
Thats a very unresponsive turbo. I can get 1 bar by 4000rpm with a 600hp GT30 Garrett.
With regard to the GT3040 comment as i said is was told it was close to a GT3040 in one conversation and in a later conversation they said it was close to a GT3530???
BHDave how long ago was it that you got your stage 2?? Have you got a turbo from a RB25DET and bolted it to your RB20DET?? When i talked to GCG they said that the reason they didnt push the stage two is the reason yours is so laggy (i am guessing). They said as per SeriesIIGTST's post on page one that all those mods where necessary to get enough air flowing to booth spool the turbo and not restrict the flow of the air it is compressing otherwise it would be laggy.
I got mine second hand and it was about 4months old at the time, probably closer to 7months old now. Came off an sr20 actually. I'd killed my turbo and it came up for a good price so i got it as a bit of a stop gap.
Id reckon they may also run into surge problems on the rb20 due to the engine not being able to flow as much as the rb25 though i haven't got to that stage yet. Gimme a couple of months.
Guest INASNT
They will say anything to sell a product!! Have u seen the size of a 3040??? The stock turbo is half the size.
The high flow is so laggy coz u r still using the stock cast manifold which is a piece of shit!!
but the highflow std turbo is still a pretty small turbo, i wouldnt think that the stock exhaust manifold is too bad for such a turbo. My 2530 is roughly equivalent in size to a highflow stock turbo, and there is pretty much no lag.
I can understand on big phat turbos like 3040's that an aftermarket exh manifold would help, but im not so sure its worth the money on small GT25's or highflow standards???
I'm in agreement with Inasnt on the advantages of the A/M manifold.
Even on a small turbo the improved flow of the new manifold will give a reasonable gain.
Only problem with getting a decent manifold on an RB that I see is that the turbo will have to be moved from it's stock location in order to get a decent manifold in there so you will need custom oil & coolant lines, intake pipe and dump.
Not a huge problem, but enough of a pain in the arse that i'm leaving it for a while longer (it also has something to do with not having enough cash to do what i want when i want) :(
Which is why you port match the manifold to the head and the turbo and then have it power ported to remove the shit you cant get to. this drops the zorst temps down 40deg. having the exhaust housing done also help with efficiency.
watch the boost rise though!!!
sorry but i am a big believer in power porting
some ppl can't afford big turbos and A/M manifolds. been down that route.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
