So I was driving to work today and when i was coming to a stop I put the clutch in and the revs just dropped to 0. I thought it was a bit strange, but I kept going. About 20 meters down the road it happened again. While on my break at work it drove it around and it was fine when it was cold since the revs would stay up but when it got warm they just dropped to zero every time i stopped. I noticed it was alot worse when the lights were on and also when I turn the lights on I can hear a squeelings noise from the engine bay. Is this an alternator problem? I thought it was something to do with the fuel pump untill I noticed the lights making a difference with the problem. Before I get flammed I did a search on the topic and couldn't find what I needed.
thanks, Dylan
Had an almost identical problem with my 32 gts-t, fine when it was cold but once it had warmed up or if it was a hot day the revs would just do whatever the hell they wanted, hunt like crazy, idle at a constant 2000rpm, or just drop straight to 0 and stall (this being the most common). However mine wasn't an electrical problem, took it into ASG who told me i needed to replace the stock ECU, my injectors were leaking and something about the AFM being wrong. Probably not a huge help to you but something to make sure isn't the case I guess.
no it wont be the alternator
check the airflow meter plug, make sure it is secure
look for any damage or excessive dirt etc
reset the stock ecu (undo battery terminal in boot (the ground cable) and press brake pedal)
if it still happens you need to get a consult cable and run stock ecu diag
last time I had the afm off I noticed that there was a fair bit of gunk built up in it, should i clean this out? Why do I need to press the brake pedal while reseting the ecu?
yes, and pressing the brake pedal drains any residual power from the ECU
thanks, Dylan
heres something weird...the same time u posted this my car started doing the exact same thing :unsure:
I find if i rev the crap out of it it often fixes itself, personally i think it is gunk buildup on the o2 sensor ..but it could be a number of things..
Hey mate i had exactly the same problem with my old R33, took to a place called NT Performance Turbocharging in Western suburbs(melbourne), dropped it off in the morning and by the afternoon i had it back, car has been fine since !!! Worth maybe giving them a call, Simon there really knows his stuff with skylines!
dont goto a workshop for something basic like that
read what the others have posted
learn how to debug and fix it yourself
the ECU has on board diagnostics so theres nothing magical a workshop can do that you cant find out
well I think it's the alternator still because my belt has been squeeling for a while, sometimes it turns over very slowly but always starts, when I turned my lights on the revs would always dip a bit. And yesterday after I reset the ECU and cleaned the afm the car was running okay untill I turned the lights on.
Check all 6 spark plugs see if all of them are covered in unburnt fuel, if they are. Check the ECT sensor
(engine coolant temperature sensor) if the sensor is dead, it over fueled the piston during idling and
will cause it to stall.
ECT sensor located at the thermostat housing by the way.
It would be the ECT sensor if the problem only occuring when the engine is hot or at the working temperature
and run smoothly while cold.
would that cause the idle to stick on 2000?
cause mine did that last week but hasn't done it again, It was on a dyno few weeks back it was running rich but didnt have time to source a problem.
There is another sensor at bottom of radiator, is that just a gauge sensor? I never put it in when I changed the radiator initially, but since I have put it back in I've been having these problems.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
