Anyone interest on Autopia which happen on 27 march 2004 at Calder park.... if anyone interested i can get you a cheap ticket for almost any even... basic enter ticket price is $12 and if you get on door is $17.. ..pls drop you email or name here and i get back to you.
http://www.autopiaenterprise.com/
Thanks
Calvin
https://www.sau.com.au/forums/topic/36112-autopiadrag-show-and-shine/
For those interested in pre-sold tickets or wanna be an entrant on the day for either show and shine, drags or both.. come to the Burvale tonight @ 8pm. If you don't know where that is, it's on the corner of Springvale rd and Burwood hwy. We'll be meeting in the car park so yeah.. presold tickets are limited so first come first serve til all sold!
I'll be there so either look out for a N1 MY03 STi or Black Honda Prelude from BMT
For more info pls check:
www.autopiaenterprise.com or contact me on [email protected]
