I have had the luck of owning some R32 Gibson cams. I had them cam doctored. Thought I would share some information as this forum has helped me quite a bit. I never installed them as they did not run a std base circle. These were machined from nissan blanks. They did run different cams for different tracks, along with a sump specific to the track. No idea what circuit these were for.
Inlet
261
9.54mm
326.4 lobe center
Exhaust
273
9.74mm
326.4 lobe center
Tolerance: 1/2 thou
May give you an insight into my own cam choice. I didn't stagger my cams as I have plenty of exhaust flow from the 3ltr.
Matt
Edited by BoostdR
https://www.sau.com.au/forums/topic/361140-gibson-r32-gtr-cam-specifications/
The base circle was 1mm under(30mm). I would just be grabbing some JUN Cams(as i have done)
JUN
IN 264 9.7 EX 272 9.7
Std 31mm base circle
No Cam lobe refuge machining
Can use with Std springs but i use Tomei Type B-9500rpm(type A-8500rpm max) which are heavier than what come with the JUN kit.
or
HKS
IN 264 10mm EX 272 10.2mm
What we found with testing JUN Cams
264 264 gives more power and better response than std cams, pretty smooth idle
264 272 gives more power than above and better spool than below, slight lump
272 272 less 500rpm response more power, little lumpy
Matt
Edited by BoostdR
272 272 less response more power
Can you give a quick overview of your specs? You mentioned 3lt but what head/manifolds/turbo/power etc.
How much did the doctoring cost?
Doctoring was $40
My specs are:
rb32
89mm CP pistons sleeved and sonic tested
264 9.7 IN&EX 0 and 0
Tomei type B springs, std retainers
Ported head 1mm over Supertech valves(short turn, bowl area only)
HKS GTRS's (port mactched exhaust housing)
Tomei Dumps-3" front pipes-3.5" exhaust-5" internal Muffler
Z32's
ARC 100mm intercooler
E85 (Liberty)
1.1mm block restrictor, Mines Baffles
6 boost Manifolds(dyno'd with chinese stainless)
Reinmax Oil pump with std springs 3.5 bar warm idle, 7.5 bar max
Howards Rods
8.55:1 Comp
1mm Cometic head gasket(good squish)
ARP throughout
Matt
Have a look at this link for cam testing on a 3SGTE. The reason I bring this up is the results we got from our own testing on a Rb26/30 was similar in curve, rpm, duration, lift and relationships apart from the 272IN and 264EX which we haven't tested and our 264/272 combo resulted in 10kw gain up top over 264/264, torque was also 150rpm later.
Cam test
Matt
Edited by BoostdR
JUN
or
HKS
Matt
Hey Matt,
So just to be clear, the above results was with the cams set at zero?
Cheers
or
HKS
I have this exact setup in my car already haha.
Will have to think about whether it's worth changing.
Interesting to see these results as they go against the grain with a lot of people.
Good work Matt. :thumbsup:
I agree cams with around that duration just seem to work really well on a mildish setup
Im on 260 10.2 270 10.2 tomei's.
After cam timing was setup these cams are very very lumpy
2.6LTR
twin 2530's
410awkw on 98
467awkw race fuel
We pieced this combo together in 2004 and to this day i cant bring myself to change a single part of the setup it destroys other gtrs with big single's and 150+hp..
Nice info matt...
2.6LTR
twin 2530's
410awkw on 98
467awkw race fuel
Nice info matt...
Great results from 2530's. What boost are your running? Additional specs would be great.
Matt
Lots of $$ invested in the head is helping alot:
Jhh ported head/built 2.6
1mm+ IN 2mm+ EX valves
Good multi angle valve job
Tomei cams as above
Extrude honed stock manifold
2530's
Almost maxed 800cc sards
Dual nismo intanks
Sorted my suspension issues out recently taking it out saturday should go bottom 10's hopefully..
2mm oversized exhaust valves? Damn, don't hear of that often. Surely that's the maximum that fits in there.
Which actuators are you using?
Fantastic result, I bet it's fun!!!
Jealous for sure
This is a Txt from my engine build on 2mm+ IN 3+Ex:
Yep it would fit in the chamber. Better if it was a 88mm bore( sleeved block) No point though as I can't remove that much material in the port or I'll find water
Actuators went from hks to 19 and now to 25psi units exhaust side must be getting close to the limits.
Quite excited to get it on e85 should be faster again with the extra torque from the fuel and push closer to 500kw if the turbos hold up..
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
