  • Replies 376
Posted Images
Is the transmission @ the front or the rear?
They are nerfing the E75 & 100 with 7.4 by moving the transmission to the front = easy engine fire everytime you get pentrated on the lower glacis...
I've also noticed that they mentioned they are reworking the frontal armor for IS8 in the patch = possible Russian tank buff again?
Yes the transmission is at the front, I am yet to have a fire because I am not a supertard and know how to hide the lower glacis. The IS-8 is currently made of paper so that's not really a big thing.
The VK4502 is the king of reverse peek-a-boo with it's rear mounted turret. Sat there while an IS-4 pounded my track for no damage over and over while I penned his front for 500 damage over and over. He lost.
Absolutely shit morning though, could not buy a win no matter what I did or how many I killed.
Actually scrap that, after reading somewhere 88JT appears to be shit.
Also wtf is with gun cirtical damage, every game I go into no matter which tank I use I always get a gun damaged critical just by low tiers spaming HEs...
Edited by Mayuri Krab
I miss good old 7.3... game has being pissing me off (more than usual) none stop ever since the update.
Close enough for me to give up WoT & play another free to play style of game instead (signed up for the beta for the new MechWarrior game) or time to dig up those old games I never finished & finish them off (like KOTOR & Mass Effect 1).
& I just pissed the E75 off, can't stand it anymore after the patch.
Now what to spend the coins on, are US tanks still worth getting?
US and Russian heavies are still good. There are some pretty bad tanks dispersed in those trees though.
Think I might need to try this game out. Is it still worth a go?
Well it's free to play so you don't lose anything testing it out.
They are also not all bad
Legacy Australia
World of Tanks donates a massive USD$55,000 to Legacy.
A huge thanks to Wargaming America, founder of the fundraising drive Nicholas Moran and all the fabulous World of Tanks supporters for this amazing donation.
Click on the photo for all the info.
That was for an ANZAC day event.
Edited by DivHunter
If you're not bad@tanks and and have/are close to tier 10 or tier 8 arty, consider joining The Steel Parachutes.
http://worldoftanks.com/community/clans/1000001873-TSP/
If you are bad@tanks and would like to improve or still working on those end game tanks you can always join TSP-P.
Go back to low tier battles as they are fun and people move together and don't spend the whole game sitting in a bush
http://worldoftanks.com/community/accounts/1000524311-DivHunter/
Tier 2, second most played tank. Churchill (train IS-4/IS-7 crew while making credits) rapidly rising in number of games. Average tier of 6.5 over 7687 games.
Teamwork (used very loosely when refering to pubs) I find is more prevalent in the higher tiers but executed just as poorly as everything else at all tiers.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
