spotted two highway patrols in box hill today near the main tram stop - looks like they were ready to pounce on drivers on each side of whitehorse road
so im guessing they are getting ready to start the blitz >,<
Graeme you're the best.
I'm not surprised they're not using it... even our standard demerit point system is bonkers compared to some I've seen in Europe.
love the cops in Europe... was on the Autostrade in Italy doing about 130-140km/h in the left lane (fast lane) as there were a bunch of trucks in the other lane... a cop comes flying up behind me flashing his lights and tailgating me, I'm thinking fark is he pulling me over!? so I pull into the right lane when I get a gap between trucks and he takes off at least 150km/h+... I was in his way and he was in a hurry apparently lol
cops are always out in numbers here over easter... yaaawn... just make your other half drive... then you can have a few cheeky ones :nyaanyaa:;)
as far as i know vic has never had double demerits, every public holiday one of these threads pop up just google the answer will be right in front of you.
You mean in general? Happens every year bro...
Speed limits in italy etc are 130kmh in general.. my gf was born and lived in rome .. well since forever (she only really just moved here) and the one thing she is paranoid is of speed limits here.
Apparently italians generally don't give much of a shit while speeding, the whole "I'm 10kmh over the 130 limit and someone is telling me to GTFO out of the way" is pretty common. Even if it's the police, lol.
That said, always best to bust out the ol Camry on long weekends :P
Yah the European roads are brilliant quality as well. I drove in a 130 zone at 180 quite a bit of the way from Barcelona through Andorra to Claremont Ferrand, even past cops, and did't once have any trouble.
My motorcycle coach was a mechanic for the Repsol Honda Moto GP team for 17 years and they used to speed the massive trucks through the country, get pulled over then bribe the cops with merch lol. Then again my other friend who lives in Barcelona got beat up by the cops in the city. There's always a flip side I guess.
Nah man.
Hoe do you peopler survive in a world you know son little about
http://www.heraldsun.com.au/news/victoria/cops-rule-out-double-demerit-point-system/story-e6frf7kx-1225937135856
Ask the resident po po man here but to mynknowledge Victoria has NEVER had double demerits and certainly doesn't this weekend.
I wish there was double penalty for the idiot I caught tonight. Drives from western suburbs to eastern suburbs 45 minutes whilst heavily intoxicated. Hits the barrier in city link 3 times and keeps going, crashes into 2 cars in Glen Waverley and keeps going. Finally we catch him leaving the scene. He blows almost 6 times the limit. Nice effort IDIOT
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
