I'm back from overseas and I'm cleaning out the shed to fund my TD06 requirments.
Precision Turbo- Billet comp wheel, PT5557 570hp turbo. Less than 1500km old, some dyno runs and a couple of gymkhana events. This turbo is currently on my rb25/R32 (some may have seen the set up in action at the DEC gymkhana event last year). The car is currntly making 250rwkw with more in it. Dyno sheet and or ride can be arranged.
Turbo- $1000
Wastegate- $350
Stock manifold wastegate adapter- $250
Package- $1400
Nismo 260km/h dash for R32 GTR- 87k kms on the clock. As far as I know it suits early 32's. $250
Generic JJR oil cooler kit- Used condition, but everything is there. $200
Twin td05 kit to suit rb26. Used condition. Manifolds are very well made (japanese) with no cracks. Turbos are in ok condition, minimal shaft play and thrust play. Comes with dump pipes. $1000
Genuine N1 oil pump- new in box. $350
Turbosmart FPR-800 fuel pressure regulator- used but in good condition, includes some fittings. $200
Turbosmart bleed valve- used. cheap. $50
Turbosmart V port blow off valve- used. also cheap. $75
VH45/Q45 V8 90mm throttle body- used but good condition. has no tps but your rb20/25 s1 will bolt straight on. also has coolant temp idle adjustment (cool!). $250
RB Flywheel- used, no cracks. $100
SPEC clutch plate- used. $50
HKS GT 2835- needs a rebuild and the housings are good. $350
RB26 conrods- straight and undamaged. $120
HKS cast low mount exhaust manifold- is don is good, but has a crack along the divider inside... I have had a quote for repair (correctly) for $150 by a cast material welding specialist. Rare item $450
HKS square base wastegate- has bolts, valve seat and gasket. $350
Trust rb26 pod adapters- good condition, needs polishing. $100
Intercooler- generic JJR. $100
Package deals can be made, all shipping will be additional (don't ask for shipping prices unless your very keen) and all parts can be inspected/picked up from south Tasmania- Hobart Area.
PM me here or call/sms
Cheers
Justin
Cooler sold to me :cheers:
If you are interested in selling that intake pipe in your first Rb25 picture, let me know. Or tell me, is it custom made or bought? If so how much and where from? Maybe you can PM me a pic of your intake system(infront of the turbo)?
Edited by SargeRX8
Sorry the intake pipe isn't for sale... it's just a 90 deg cast trust pipe and a 90 deg alloy bend... there's no provision for bov return or breather intake.
Cheers
Justin
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
