I'm back from overseas and I'm cleaning out the shed to fund my TD06 requirments.
Precision Turbo- Billet comp wheel, PT5557 570hp turbo. Less than 1500km old, some dyno runs and a couple of gymkhana events. This turbo is currently on my rb25/R32 (some may have seen the set up in action at the DEC gymkhana event last year). The car is currntly making 250rwkw with more in it. Dyno sheet and or ride can be arranged.
Turbo- $1000
Wastegate- $350
Stock manifold wastegate adapter- $250
Package- $1400
Nismo 260km/h dash for R32 GTR- 87k kms on the clock. As far as I know it suits early 32's. $250
Generic JJR oil cooler kit- Used condition, but everything is there. $200
Twin td05 kit to suit rb26. Used condition. Manifolds are very well made (japanese) with no cracks. Turbos are in ok condition, minimal shaft play and thrust play. Comes with dump pipes. $1000
Genuine N1 oil pump- new in box. $350
Turbosmart FPR-800 fuel pressure regulator- used but in good condition, includes some fittings. $200
Turbosmart bleed valve- used. cheap. $50
Turbosmart V port blow off valve- used. also cheap. $75
VH45/Q45 V8 90mm throttle body- used but good condition. has no tps but your rb20/25 s1 will bolt straight on. also has coolant temp idle adjustment (cool!). $250
RB Flywheel- used, no cracks. $100
SPEC clutch plate- used. $50
HKS GT 2835- needs a rebuild and the housings are good. $350
RB26 conrods- straight and undamaged. $120
HKS cast low mount exhaust manifold- is don is good, but has a crack along the divider inside... I have had a quote for repair (correctly) for $150 by a cast material welding specialist. Rare item $450
HKS square base wastegate- has bolts, valve seat and gasket. $350
Trust rb26 pod adapters- good condition, needs polishing. $100
Intercooler- generic JJR. $100
Package deals can be made, all shipping will be additional (don't ask for shipping prices unless your very keen) and all parts can be inspected/picked up from south Tasmania- Hobart Area.
PM me here or call/sms
Cheers
Justin
Cooler sold to me :cheers:
If you are interested in selling that intake pipe in your first Rb25 picture, let me know. Or tell me, is it custom made or bought? If so how much and where from? Maybe you can PM me a pic of your intake system(infront of the turbo)?
Edited by SargeRX8
Sorry the intake pipe isn't for sale... it's just a 90 deg cast trust pipe and a 90 deg alloy bend... there's no provision for bov return or breather intake.
Cheers
Justin
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
