Currently in Sydney
2G firm....
original aerotech buckets
VN group A (NSV build with build plate)
original CSA alloys...
identical interor to orginal and exterior with all badges...
(seats alone would be worth at least 4g........)
143000km
chris
0478058818
email: [email protected]
  • Replies 44
more pics to come when i find them....
wont let me upload i will have to alter the type and then upload.....
i know.... i had some on face book but the pics have vannished due to my Facebook account being hacked and/ or it being monitored by the feds / acers/ asio/ asssic / dsto intelligence surveilance and recon etc... will post them up when i can find them.....
the seats and rims are phat.... best buckets i have ever sat in from a factory spec car..... they are awesome....
has stiff suspension too...... damn stiff,..... handles like it is on rails however it could do with some expensive rubber....
no do not have any dyno sheets... it is prob not more than 120 kw at the wheels with the current set up... if need be i can get you a VP commodore motor with a twin turbo sr20 set up with dump pipes and cooler and piping aswell as braided lines that has been pro built for about 1600 more... that should be good for a safe 200kw at the wheels.... not bad for 3500 approx all up....
chris 0478058818
But dyno sheets help us tell how the car drives! It's an important part of selling a car, how else are we going to be able to tell how it behaves on the road?
Hi, can the stock R33 cat be included in this sale?
probably the only thing you would ever get related to gina -- some stocky exhaust part - (catconverter) and if you did happen to get sum, no doubt you would pay for it too............
pics of car please?
i have lost the cable that connects my phone to my computer so hence can not load photos of the car.... as soon as i find this cable i will upload.... for some reason the photos on face book that i have of the car are not supported on this site???
it is an unmodded stockish Group A where everything is identical to the real thing except for the transmission, motor and the steering whee (it was built by Northern SPecial Vehicles and has a build plate.....
if it had been modded and had been retuned due to having some form of engine management i would defenitely put in a dyno sheet... and if you were looking for a high hp car for either track. drift or drat (which this is not) i would agree with you that a dyno sheet is a must to determine how it behaves etc.....
However i know that you are being a smart arse product of a wank stain and put this comment in for a laugh due to the comments which started the macdoogle files hehehehehee... have a good day smart arse!!!
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
    • Sounds good. Provided the panel is flat/level I'd be happy to start the painting process.  While you are learning, for sure you could do this. Its only paint, you can always sand it all back and start again. Its only your time and money on materials, but while you're learning, really its time and money spent on your education.  Once you know how to do this bodywork and painting, you won't want to waste your time and money on frivolous activities lol.
    • Yep I will use a guide coat after putting filler, I will do it on the whole panel as I'm a beginner so chances I've made quite a few errors. In that photo, I think that was a low spot, I just for example said to pretend it's flat but I will put filler + guide coat after to assess where I'm at. Yep with that picture, the panel is wet as it rained when I took the photo. But all those scratches are completely smooth, I went over it with 240 grit and can't feel it, even with my nail digging into it. I was legit thinking to buy a 2k can and spray primer to see how it turns out but then thought to myself it's going to be a mess doing it haha. Good mention there. Thanks for all that info I think I know what to do next.
    • Prior to laying down the primer, you need to make sure the surface is completely level. For example, based on this picture, I strongly suspect that the areas marked in blue are higher then the area marked in green.  If you spray primer over this entire area, then paint and clear it, the finished result will 100% show the low area. It will stick out like dogs balls. Unfortunately the paint won't magically level out the low areas as you lay it down.  Without seeing it in person, I expect that the green area will need to be filled, then use a guide coat and check that the entire repair area is level with a large sanding block.  With this picture, are you saying that even though you can see the scratches, the panel is in fact completely smooth and flat? If this is the case sure you could prep and paint it as it is.     The picture with the paint you described as blistering, it's hard for me to comment on from the photo alone. It looks like the panel is wet? Dunno, looks strange. Does the panel feel as smooth as glass when you run your hand over it? **** Going back to your question again, generally you would only sand the primer if you made a mistake while laying down the primer.  If the panel is prepped properly and you lay the primer down properly, you should not need to sand the primer.  This wouldn't work - Don't prep the panel. Spray primer and see how it turns out. Sand the areas where the issues appear. Spray more primer and see how it turns out. Sand the areas....... Yeah you'd go round and round in circles getting no where.
