I've just started having noisy hydraulic lifters. The car drives perfectly fine, it just suddenly started to gone noisy. I've pulled out all the inlet side lifters and they seems to be fine.
Yes I searched and found this:
http://ashspecz.com/Image%20Gallery/Lifter%20Rebuild/index.htm
but I'm having issues pulling them apart. Any one actually managed to rebuild them per those instructions?
Also could there be any thing else that would cause this issue? ie, oil pump and etc. any advise would be great.
Thanks.
PS. its stock RB25det with factory engine head
Edited by kwickr33
https://www.sau.com.au/forums/topic/361912-hydraulic-lifters-noisy/
hey mate i stripped mine down few months ago and gave em a clean up. followed DIY that someone put up possibly same as the one you posted but i cracked 2. said to put on solid surface and hit the top but this dented the tops and cracked the sides.
the simple solution was to hold each lifter with index and ring fingers down the sides in the groove and middle finger over the top. then line it up square with a hard surface(i used an anvil) then give it a tap until you learn how much force it takes to pop them(actually not that much if the surface is solid enough). then gently with pliers pull out the barrel. also in the DIY i went off it said to put all the parts in tin of cleaner but i didnt want to mix them all up and i wasnt going to do this exersize for 24 days. so i used a fishing tackle kit which swelled up a bit but worked well. mine are still in same kit soaked in oil til i get round to putting it back together.
soaking in mineral spirits then i scrubbed them
all cleaned up then i filled container with oil
Thanks for the info. I managed to pull out all 23 of them except 1. I found that I didn't needed to tab them out. I Just pulled them apart used square head plyers.
How ever there is one that I can not pull it apart. The bit the the center press and spins, but regardless how hard I tab it or pull it I can not pull it apart. Would that be the faulty lifter?
I think new lifters are around the $100 a pop sort of mark... (X24)
the one that you can't get apart though, have you poked a pin into the ball on one end as you're pulling them apart? I found that a lot of them didn't need this, but some did. Once mine were all done and refilled with oil they wouldn't come apart unless pushing that ball in.
wait, reread your post. Have you got the telescoping part out of the middle yet? Or is it still as it was when it came out of the head?
Easy job once you get the hang of the first one how to take it apart and put it together. You just hit the lifter against a flat surface progressively harder unto you see it pop out then as others said pull it out with pliers. I found using a wooden table best as there wouldnt be any damage done to the lifter.
One other thing to keep in mind in the instructions it says when assembling them back together to try and push it together to get it in the circlip that is actually very hard to do what I did was easy way that took 5 sec. Make sure its lined up as says and put on flat table and push down from the top and it will click in no worries providing you have it lined up with the circlip.
yeah nissan want your first born for a set of lifters. this is from a while back.
Hi there mate
in the event that anyone wants to buy lifters for there rb25det, the link has them for 408 dollars for a set of 24
FYI the lifters are the same as a 300zx twin turbo Z32 model. 1990-1996. Hope this helps anyone thats in my situation. the part number is LIFD27 by Topline
:P:laugh:
http://www.importperformanceparts.net/
the site seems to have changed a bit as i couldnt find a reference to rb25 but lifd27 is still there for 300xz turbo and n/a plus ca16de and ca18de for $17 each
Even at 17 each your still looking at a few hundred for a few set when cleaning them isnt to hard just get the hang of it. You only need to buy them if there completely seized or have to much play.
How much are new lifters?
I just bought a set of new ones from the states, i paid ~AU$12 each and $50 postage. Nissan wanted $140 each for them which is a joke.
these are the guys that i bought them from, their part number for them is "LIF 630"
http://www.rockauto.com/catalog/catalog.php
Don't buy them from these guys, i ordered a set through them and i never received all 16 (CA18)
http://cgi.ebay.com.au/Lifter-NISSAN-CAR-2960-3-0L-DOHC-V6-VG30DETT-24V-Turbo-/290487861887?pt=Motors_Car_Truck_Parts_Accessories&hash=item43a26d027f
Edited by D_Stirls
Just replace your engine oil with a diesel engine oil and run it (softly) for a few km's.. Diesel engine oil contains a detergent that will clean out the sludge that builds up in the lifters.
Just flush it through well after.
J.
J.
If there is enough sludge in there for it to be ticking loud this probably wont work as you will have to disassemble it to give it a real good clean inside, I get a tooth brush and get in there scrubbing it all out with gun wash then let them soak in it for a few hours.
Well its not that obvious with massive sludge coming out but just little builds up of sludge will make it not function properly and when you clean it out you wont see it cause it all gets mixed up in the oil and whatever cleaning agent you used.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
