so i am currently cutting the plugs off my factory injector loom and crimping/attaching new plugs for my id1000s.
im a sparky by trade so have no problems make new connections but im confused on polarity.
my id1000s are polarity sensitive and have + and - marked on the injector head at the corrosponding pins. in my factory loom i need to know if the common grey cable that is shared between all injectors the negative or positive???
is the single wire that is dedicated to each injector positive or negative?
i just cant remember if the injectors work on switched the earth or switching the active.
Edited by tm_r33
https://www.sau.com.au/forums/topic/361941-injector-loom-help/
just looking at some wiring diagrams now and it looks to me like the wire that is common between the 6 injectors is the + and the individual wire to each injector is -
(they work by the ecu switching off/on an earth)
sound right?
I had the same issue with my ID1000's, I asked the injector specialist and he told me not to worry as its just a coil with no reason to suggest a polarity on the plug as either way would energise it. I still wired them up as per the plug though and obviously have no issue.
Im temporarily running the stock turbo at the moment until my GTX comes this week and it idles perfectly on ethanol with the 1000's. :thumbsup:
yer sweet i wired them up with + in correct position but so hopefully no dramas. i wish they came with a patch loom like my haltech lol.
i hate make looms. im too anal so ive spent 8 hours on it today ( im still going) cause im just not quiet happy with how it looks on top of the motor so i keep changing it lol.
tape.... no tape.
split tubing...... no split tubing.
heat shrink..... no heat shrink.
combination of all of the above...... nar looks shit.
ill keep working away and post some high res pics of loom and loom on motor when im done.
cheers guys
  • 1 year later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
