  • Replies 232
Hoping to go. I havent met any of you guys yet. Is it ok to just turn up. I will be bringing sxe32 with me. may just go in one car instead of both.
Certainly is fine to just show up... Just come and mingle with the group of people around the skylines... :)
And BOO at only one car.... Just make sure it's a sedan :)
well you can count me in I hope depends on what time I get off work :) not set finish time means not to sure but sounds like it is going to be a great night
oh hey slip I seen you after a night out on the turps mate you will be all good lol
See uz all there I hope :(
+ been a long time between cruzes for me too :ufo:
As the event organiser, I will allow the exception of Squizz and Dave to bring their Cefiros. Both are long term friends of mine and I see no harm in them bringing the two cefiros.
I really can't see how we can stop squizz from attending the cruise in his own car. He's a long term site supporter and a moderator and seeming this isn't an "official event" (read: not a club event because the club hasn't started yet) I don't see why there would be no reason for Squizz and Dave to be left out.
I really don't think people are going to look at us and say "OMG.. theres two cars in that cruise that aren't skylines.. omg how could they do that". If they were real car enthuisiasts, they would realise what type of car they are and understand why they are there.
If anyone has any issues with this, please raise it in pm, not in this thread.
Looks like I'll be there or be square! But Erin, seems there is a LOT of people going. What are we going to do if the carpark is still closed off??? Because I dont think maccas would want us.
Wholley begeebes dave! I totally forgot about that.
Hrm. This could prove... hard.
I might ring up and find out who manages the property and ask how long it's going to be before the carpark is fixed.
Actually. Alternatively, There is the other carpark across the road where the red rooster is that is a shopping centre carpark as well. That might be a goer.
Time for a mass pm I think.
ok guys i am in the working of getting my r32 trading in my pulsar with a gtir motor however i may not have ownership of the car at that time am i still able to meet up and greet everyone ????
Hey mate, hows things??
What type of R32 you getting??
Cheers Cam
Thats right Erin! Im not just a pretty face, infact some would say not even that! :D
hehe this cruise in on my bday :)
I probably wont have my car how i want it for the cruise either :P
Got lots to do yet, need to install IC, safc, avcr, sitc, vs rearbar, ces split dump then get it all tuned
oh and gotta book it in for whiteline works kit minus the shocks&springs
tight squedule :)
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
