I'm in the process of getting my R33 S2 Rb25 tuned with nistune on a std R33 ECU. When we put it on the dyno yesterday, the graph showed a sudden loss of power at about 5000 rpm or 160km/h in 4th, with the car reving noticeably slower and occasionally backfiring. We wern't able to tune it out, the best we could get it was to stay flat from 5000rpm onwards, but this required a noticeable jump in ingnition timings around that rpm i.e. 17-18-18-21-23-24 ect. Highest power reading we had was 210KW
Uploaded with ImageShack.us
The car has the following modifications
FMIC
3" exhaust
Hi flowed hypergear turbo @ 14psi
Z32 AFM
GTR fuel pump
Spark plugs are R5671A-7 gaped to .7 . I have investigated the coils before while experiencing rich and retard and have coated them in high temp silicon, but i could never find any cracks, or see any sparks in the dark.
Boost started at 14psi and gradually dropped to 12psi by redline.
Any ideas for whats causing this drop off in power?
What cat?
Done a run without exhaust?
Double checked base timing etc?
Cam belt isn't out a tooth?
Boost drop means actuator might not be setup right?
Are the plugs iri? You sure they are ok? (in future use coppers please!)
That's enough to start.
This.....
Cannot be
Correct.
OP, your options are;
1. R32 CPU without VCT, or with an external VCT controller
3. Z32 CPU
Nistune does NOT support the R33 ECU. So which ECU do you really have?
Looks like this sort of behavior:
Above was from worn valve springs and valves. That dip could not be controlled by timing or fuel, the depth of the dip is random.
Also you are likely to need high pressure actuator to hold boost steady up top.
The car is being tuned using an ostrich emulator on the R33 std ECU which will then be burned to a permanent chip once finished. Tuned by toshi who has done many cars on here this way
I believe the cat is a high flow, but it was there when i purchased. I've had it off before and its definatly 3" and you can see through it with a spiral type alloy fins inside
I did not do a run without the exhaust
Base timing was checked and is correct at 15 degrees
Have not checked cam belt, but have not touched it either
The plugs are copper, and have only done about 5000km, but this will be the first thing i change.
As for wastegate problems, the boost drop is very gradual, and i cant see this accounting for a sharp drop in power and noticeable slowing of reving. It was so sharp that on some of the runs the dyno would stop recording after 5500rpm as it thought peak power had been reached.
Also forgot to mention that the car would backfire once on some of the runs. Also the tuner said that the ignition timings we were running would usually cause pinging, but he was surprised that it was not.
Thanks for the replys so far :thumbsup:
Edit: My KW graph looked a lot like the torque graph above, but staying flat through the 6000-7000rpm range
Edited by Sparky206
had a similar problem myself. It was the stock rubber intake pipe distorting/sucking shut.
my symptoms led me to find this out as it was doing it more when the conditions were warmer (therefor rubber is softer and more able to be sucked n distorted).
I put in a metal intake pipe n that sorted it perfectly.
if you are only every going to go for about this power (famous last words) then one of the cheaper silicone intake pipes may suffice but otherwise i highly reccomend a metal one.
It also means more power is possible in the top end due to the better air flow.
I went from 290rwhp @14psi(when the intake wasnt sucking shut) to 300rwhp @14.5psi (the intake allowed for a bit more boost) just by replacing the intake.
Consistent with exhaust valve spring issues ???
Did you have a similar power curve to the torque curve above with an almost instant abrupt loss of power?
hey mate,
when my car was tuned it did the same sorta thing.......simple problem and wondering whether or not you have checked to see if your air filter plumbing is sucking closed. this would probably??? show up on tune graphs (a/r ratios etc).
we reinforced it and hey presto everything ok.
hope you can sort it out
Mick
If that is a final run with correct dyno settings on full throttle I would suggest to check the factory actuator adjustments or it’s in need of a better actuator or a leak from some where.
else it was very similar to mine when I discovered the valve issue, I could initially get away from that dip by patching up timing and till it stopped responding and the depth of the dip became random. The R33 Rb25det would generally give a small dip after 6800RPMs while Neo engines don't.
Did everyone miss where he said it backfires? Backfire sounds like it is missing, for it to miss it sounds almost certianly like an ignition issue, old shagged coilpacks almost always cause a miss around peak torque (4500-5500rpm). There are loads of threads about this issue, surely this has to be the problem?
Check the spark plug gap as well, 0.8 is the largest I would go. Toshi is in Japan, most japs tune the cars very rich around 10:1 from what I've seen, this exaggerates any weak spark problems massively making any misses due to poor spark even worse, you don't have to see cracks/etc for the coils to be stuffed, mine looked perfect and were stuffed, fixing the tune up from 10:1 to 12:1 completely removed the misfire in my situation as well.
The only other thing I would bet money on is the intake sucking shut, but I can't see how this would cause a misfire.
edit: You say you have an R33 ecu but these cannot be nistuned, the most likely option is an R32 ecu, however these can't control VCT, how is your VCT being controlled? If it isn't switching off at 5000rpm correctly and is keeping the exhaust cam retarded you will see a big dip in power over 5000rpm, make sure the VCT is switching on and off correctly at the right rpm, this could also be your issue, I can't see it would cause any backfires though.
edit2: just saw that it wasn't nistuned, ignore my first edit.
Edited by Rolls
    • Thanks. That's what I was after. One of the kits, the o-ring side is too big diameter. The other kit is a plate with a o-ring to seal and the hose connection offset.
    • Are you using the factory rail?  Is there any reason you don't want to use one of the two you already have, they don't have to attach to the fuel rail directly.  If you 100% must have a FPR that directly bolts to the fuel rail, you could get a Radium setup. I use a radium fuel rail and the direct mount regulator, it is quite a sexy setup.
    • https://www.google.com/search?q=adjustable+fuel+pressure+regulator+nissan+fuel+rail+adapter&sca_esv=6710113de42d5150&source=hp&ei=GhPbaNHfNZeinesPyPqEiQc&iflsig=AOw8s4IAAAAAaNshKnLkjQGMWYT5EyclmXEJm8ZXSWDb&ved=0ahUKEwjR1JOCjf-PAxUXUWcHHUg9IXEQ4dUDCCE&uact=5&oq=adjustable+fuel+pressure+regulator+nissan+fuel+rail+adapter&gs_lp=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_EFhqEHecdnjv2SBwYyLjU1LjGgB7XnArIHBjAuNTUuMbgH4UXCBwgwLjUuNTEuMsgHiQI&sclient=gws-wiz
    • I had the fuel rail out to check the injectors before getting the ECU reprogrammed. The guy said that the injectors were fine, but the regulator was cactus (leaking fuel out the vac port, randomly changing pressure. I decided to replace the FPR with an adjustable unit. I have purchased 2 now, and neither has an appropriate adapter to fit where the FPR mounts. I need advice on where I can get an adjustable FPR that will simply drop in on a RB25DET. TIA
