Hi All
Up for sale is a brand new nismo 300km cluster for a r34 GTT..
I bought this with the intention to use on my 34 but I may be selling it so im going to pass this one off..
These are on back order from nismo and will set you back close to $800 delivered..
Im letting this one go for $710 FIRM posted anywhere in aus..
It has only been taken out of the box for pictures..
Either msg me on 0412589924 with a name or pm me here on sau.. As i usually cant answer my phone at work and will call you back as soon as im free.
https://www.sau.com.au/forums/topic/362969-r34-gtt-nismo-cluster/
^^ Can you pickup from Nengun?
Knowing nengun will probably slap a $200 freight on it and takes 129830912830912 months before it gets send out from Japan
Edited by ichi-go
total from Nengun is 705 delivered, plus the wait for it being on back order..
so if u want to go that way feel free but unless you are interested in details of what im selling keep it to yourself
