Hey guys
Just bought a gtt and can't seem to find a website telling me if it has a stock alarm/immobilizer. I'm confident it doesn't because I locked it with the remote then opened it with they key and started it fine.
So I'm assuming no alarm system what so ever.
I live in the Wollongong nsw and was wondering what's a cheap way to get insured, (needing alarm and immobilizer), I don't want anything annoying that beeps at me if I haven't locked the door or anything like that.
Just minimum to get insured
Thanks
https://www.sau.com.au/forums/topic/363064-2000-s2-r34-gtt-stock-alarm/
they can have factory alarms but they wont' comply with ADR rules for insurance nor will they stop a scum , don't buy a min alarm for a skyline, and don't hook up a remote start or turbo timer function.
you need one that is compliant to the ADR rules for alarms and then add more to that asap to stop it from being stolen. just look at the SA forums, every other week 5-10 go missing
nothing is safe these days. SCUMBAGS who steal cars !!!!!!
read the PDS for shannons, Just cars has the similar requirements for coverage
Shannons PDS link
/unfriend :P
you have been reading to much about me :)
as for decent alarms - autowatch,mongoose or viper (yes the do make a black wire one.). preference is the autowatch due to size. also find someone that can install. by htat I mean properly and not simply tossed under the dash.
if they pull parts of the dash out and hide it - great . if they pull the whole dash - even better.
Hmm I might get the 555 central locking module. Do you know anywhere in Wollongong nsw that can install??
so ive done a bit of research on alarms and was wondering if you knew if a gtt factory central locking has code hopping in the remote?? if not ill probly get a cheaper one (opposed to the 555 module) and have a seperate alarm remote. the only thing my shadow alarm lacks is more sensors it seems. it only comes with one door sensor.
Well the 555 module is a attachment to the central locking coil. So if the central locking button doesn't have code hopping there's no point putting that expensive alarm in because they'll be able to pick up the code and it'll be te same every time.
So it'll be an external alarm rather then off the central locking :)
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
