Howdy all,
Well the Thursday night meets/cruises seem to be going excellent, great turnouts each time and great to catch up with other line owners, hoping some knowledge will rub off on this noob :cheers:
Anyway I love to get along, but unfortunatly I have to work on Fridays and like Erin, like my sleep, and was wondering if we could change it to another night.
Obviously I am not asking to change it just for me, so vote in the poll and we'll see if everyone is happy to keep it on Thursday's or not.
Thanks!
https://www.sau.com.au/forums/topic/36318-meetcruise-nights/
Yeah I thought about that, but I'd really like to know which particular night people are interested, so if all of the above apply then just pick one that you would like to see become the regular night.
https://www.sau.com.au/forums/topic/36318-meetcruise-nights/#findComment-724489
Try 5am, yes I know I sound like a wus or a whinger and I dont mind the thursday night meets, just means my intake of coffee for friday quadruples :cheers: That is why I just wanted to get an idea, that's all.
But call me weak if you want but unfortunatly my body just does not really work all that well on 5 hours sleep.
https://www.sau.com.au/forums/topic/36318-meetcruise-nights/#findComment-724523
Looks like there is a trend emerging on the poll, :cheers:
I reckon thursday is a much better day for cruising as it is a weekday meaning less cops, less traffic, less bogans out, only problem for me is the work the next day, but hey you know what Hitler says, "Whatever does not kill you can only make you stronger."
https://www.sau.com.au/forums/topic/36318-meetcruise-nights/#findComment-724530
I have to get up at 5:30am for work the next day but Thursday is still more suitable for most of the above reasons already stated. That way it doesn't clash with other weekend events and should keep the numbers consistant.
https://www.sau.com.au/forums/topic/36318-meetcruise-nights/#findComment-724545
i have to be at work at 5:30, but i still go out, just means i drink more redbull/V :cheers:
sleep when i get home after fridays anyway, and most of the time its worth staying up :D
changing it to a monday night or such, will only make things harder for people, such as I get paid thursdays, and if something went wrong for some god aweful reason I would be abel to get it fixed pretty much striaght away.
but yeah im fine with any night if something changes.
https://www.sau.com.au/forums/topic/36318-meetcruise-nights/#findComment-724568
thursday is still good for me. So far, none of these have had me back home any later than 12am.. So that leaves plenty of hours to get sleep in even if you have to work the next day.
Friday and Saturdays you get associated with the "usual" cruise/pack mentality and I think there will be problems there. The roads are much more busy also.
https://www.sau.com.au/forums/topic/36318-meetcruise-nights/#findComment-727058
Im happy any day of the week. I think i'm going to have to give up thursdays soon because i cant keep using the same excuse while i always miss my first 2 classes on a thursday.
Friday or saturday nights are proberlly the mose nights people are out.
Friday nights everyones at Harrys Diner
Saturdays Everyones at BWCP
https://www.sau.com.au/forums/topic/36318-meetcruise-nights/#findComment-727212
what goes on with these cuiz nights, like were do u meet up,what do u get up to, and who gets to go?
Mate...
The meeting spots rotate so everyone gets a fair deal... Brissy 1 week, GC the next...
What do we do? Talk for a bit.. Go for a leisurly drive to show off our pride and joy... Sometimes a spirited drive through some of the better roads around...
Anyone is welcome... C'mon down! We had a Mirage show up last week... :P There are new guys every week so you wont be out of place...
https://www.sau.com.au/forums/topic/36318-meetcruise-nights/#findComment-727878
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
