Thinking of heading to wsid when i get a chance . My car is a 34 gtr vspec with 381 kw at wheels, Im running 295 pirelli semis on rear and advans on front so traction is pretty good.
What et and mph would you guys think is achievable?
Its not my first time at the dragstrip so i know what im doing and know how to drive a car by the way.
11.0- 14.0.
Just go n try, what times have u done before hand n try n go off that.
I went 10.93 with 418 kw n Mickey Thompson tyres at 129 mph. But could of still been faster.
Ye you should be into the high 10s
I'm off to the strip in 2 weeks to see where i can get with 365rwkw, im hoping deep 11 or a high 10
See how it goes. Long as i get a decent 60ft and super fast shifts, should be good times laid down
My brother's R33 GTS-t was making ~465rwhp and he ran a 12.6sec 1/4mile @ 225km/h on street tyres. No traction till 3rd gear. His ET was faster than cars that were running high 10's....
I would say anywhere between a high-10 and a mid-11 if you launch properly....
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
