just wondering how many ,close to rev limit launches, or on the limiter, a standard r33 GTR box will handle.
its in an r32 GTR with an os giken triple plate clutch, and 330 kw atw.
i recently started going to the strip and love it, but just wondering if the gearbox will survive.
cheers
  • Replies 64
Posted Images
mate its hard to say on these type of things, some could last forever and some could go on your first (depending on km's and alot of other factors) give it regular services and try for second gear lanuches, your syncros will die first usally folowed by first gear, its just like asking how long will a engine last if i limiter bash it, could be years or days, all depends on previous wear.
man.... ive had my gtr for 2 years. 312kw ive done a nite a the drags. and about 100 limiter dumps on the street!! see my sig!!!
they love it hahaha
how long is your string?
your unlikely to break 1st gear, but stuff will wear out, clutches, syncros, transfer case etc, being a 32, are you launching 4wd ?
I would've launched 1st in my last R33 GTR up around a couple hundred times in a few years with no gearbox issues, just a few clutches.. however did smash the gearbox dropping 2nd while rolling..
anyway just go for it, you probably spend more on clutches than gearboxes
my bad, was going off my experience with my rwd not awd, theres no need near redline drop anyways, just get yourself a launch controller activated by handbrake and find the sweet spot rpm just before it will break traction
I'm into the hundreds of launches in my race car.
the most important thing is not to shock it by dropping the clutch cold.
just before launching put the handbrake on and let the clutch out a little to put the drivetrain under load. when the light goes out, drop the handbrake, drop the clutch, floor the throttle and watch it go.
cheers guys,
not so worried now after hearing that,
might just give it hell, and see how long it lasts.
is there any cheapish ways of making them stronger, i have looked at the OS Giken gear sets, and others, but they are so expensive, and the car isnt that powerful. ??
plus its only a street car!!!
cheers guys,
standard box should be fine, just do what Duncan said and pre-load the drive train,
I think the high rev launch is more to not bogging rather than breaking traction...
yep by the looks of the OP's sig he's got a big single, I'm the same, launch any lower than 7krpm and it just bogs down.
get it right and ------
right you are!!!!
anything under 7000-7500 and it bogs down. high boost (1.5 bar)
low boost bogs even nearer to rev limit. (1 bar)
high rpm launch in the wet with lots of wheel spin.
Here's a good one;
Very nice. I still dont quite get the perfect launching technique with the GTR though. Everyone seems to tell me to dump it at around 6500-7000 but this thread says 1/2 clutch with handbrake.
yeah anywhere between 6500--limiter, the handbrake is just to load up the drivetrain before you launch.. on the line put on handbrake in 1st gear, let clutch out a little so it pushes against the handbrake, then clutch back in, handbrake off, don't let car roll back and drivetrain is loaded..right foot down and step off clutch..hang on..:woot:
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
