Hi All,
I'm after a stuffed RB26 head. I don't care if it's cracked, warped, got a ferret stuck in a port (common problem on RB26's). Only condition is it must be very cheap. I just want it to put on a buggered block I have in the shed and make a dummy engine I can fit in the engine bay and see how everything is going to fit. Basically after something that was destined for scrap metal.
I'm also chasing a slave cylinder, throwout fork and bearing for an R34 GTT box.
Cheers,
Shane
Hi All,
Cheers,
Shane
i have a 20 head you can have if that any use to you.
Thanks, does anyone know if some of the studs on the inlet side line up between a 20 & 26? I know most of the exhaust studs do. If I can get a few to line up then it will do the job for what I'm after.
I'm also after the rear part of an R33 or R34 tailshaft if anyone has one.
Thanks, does anyone know if some of the studs on the inlet side line up between a 20 and 26? I know most of the exhaust studs do. If I can get a few to line up then it will do the job for what I'm after.
all bar 4 of the studs line up between rb20 and 26 on the inlet and i think similar on the exhaust
i also have rear half of r33 tail shaft
and i have a rb25det head that is only any good as a paper weight so you can get the whole lot off me if you want.
if you need the yoke for the gearbox i have a new one spare
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
