WANTED
4.375:1 rear diff gear set for my r32 GTR (have a front set).
Cheers
Justin
i got mine through SSS automotive in NSW, same as you had a front already.
http://www.sssautomotive.com.au/
cost me about $450 for the complete rear diff pumpkin, just put my GTR LSD in the centre they sent me,
as the GTS4 has a viscous LSD
total cost was $650 after a put a Nismo kit through my LSD.
Cheers
wtb, R33 series 1 headlights. Don't need to be perfect condition. Let me know what you've got :)
cheapest place to grab them is Ebay,
http://www.ebay.com.au/itm/Nissan-ECR33-S1-Series-1-Zenki-RH-side-Head-light-JDM-s15-c33-a31-r32-r33-GTR-/280932778465?pt=AU_Car_Parts_Accessories&hash=item4168e601e1
to buy them in the trade you'll at least $200
Cheers
hi all!
im chacing a front bar to suit r33 series 2. with or without indicators/fog lights.
something that needs minor repair is fine,,, look at almost anything!!!
pm , call or txt ,. ph 0417589201
Still after the following for the 32:
- Front bar (would prefer standard GTST bar).
- Right projector type headlight.
- Left Type M side skirt.
- GTST bonnet latch.
And considering if anyone's got them:
- Screamer.
- 3" front pipe.
- x2 3" stainless 2 bolt exhaust flanges.
Will probably just buy these bits new but worth asking!
Edited by Bushy
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
