Wanted to sell
RB25 gearbox conversion package.
Suit rb or sr/jz with adapter plate.
Located northwest.
$1600 ph 0409 631 092
Full package, had good oil, no swarf, drove excellently. 145xxx km behind stock engine with dampened clutch.
-one gearbox with shifter and all sensors
-clutch slave
-tailshaft
-all bell housing bolts
-crossmember and mount (R33)
RB20, 25, 30 clutch and flywheel
Located northwest.
$800 ph 0409 631 092
ORC-409D-01N (R32, R33)
The ORC 409 Single Plate Metal Clutch Kit Nissan is the Competitive Single Plate Clutch kit by Ogura Racing. The clutch is the damper type which will maintain streetability and handle up to 400ps in addition to having excellent engine response with the lightweight chromoly flywheel.
Throw out bearing/carrier/sleeve, flywheel bolts and clutch bolts are included.
Heaps of meat left, have driven this and other Orc 409d, epic clutches, easy to drive but heaps of bite. Basically "the" drift clutch in Japan.
Looking for a good condition R32/S13/Z32 etc adjustable Passenger side rear camber arm. Will buy new or second hand and will buy a pair as well if someone has anything kicking about? 0401739292
Edited by tobs_r32
  • 1 month later...
  • 5 weeks later...
Needed Urgently:
- R32 GTST standard drivers seat belt buckle (I would consider whole drivers seat if not willing to separate).
- R32 GTST headlight projector globe clip (this holds the globe and attaches to the headlight via a circlip type clip that then connects to the headlight loom).
Located Hobart but happy to pay for postage, or travel.
PM or 0439182091
  • 1 month later...
Wanted, set of r33 gtr wheels, tyres aren't a huge concern. I would prefer to buy but I also have a set of 17x9 +10 work meisters I might be willing to swap
Your meisters.... How much ?
1992 R32GTR
T51R SPL 24psi
Apexi power FC
OS Gikken quad plate
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
