Wanted to sell
RB25 gearbox conversion package.
Suit rb or sr/jz with adapter plate.
Located northwest.
$1600 ph 0409 631 092
Full package, had good oil, no swarf, drove excellently. 145xxx km behind stock engine with dampened clutch.
-one gearbox with shifter and all sensors
-clutch slave
-tailshaft
-all bell housing bolts
-crossmember and mount (R33)
RB20, 25, 30 clutch and flywheel
Located northwest.
$800 ph 0409 631 092
ORC-409D-01N (R32, R33)
The ORC 409 Single Plate Metal Clutch Kit Nissan is the Competitive Single Plate Clutch kit by Ogura Racing. The clutch is the damper type which will maintain streetability and handle up to 400ps in addition to having excellent engine response with the lightweight chromoly flywheel.
Throw out bearing/carrier/sleeve, flywheel bolts and clutch bolts are included.
Heaps of meat left, have driven this and other Orc 409d, epic clutches, easy to drive but heaps of bite. Basically "the" drift clutch in Japan.
Looking for a good condition R32/S13/Z32 etc adjustable Passenger side rear camber arm. Will buy new or second hand and will buy a pair as well if someone has anything kicking about? 0401739292
Edited by tobs_r32
  • 1 month later...
  • 5 weeks later...
Needed Urgently:
- R32 GTST standard drivers seat belt buckle (I would consider whole drivers seat if not willing to separate).
- R32 GTST headlight projector globe clip (this holds the globe and attaches to the headlight via a circlip type clip that then connects to the headlight loom).
Located Hobart but happy to pay for postage, or travel.
PM or 0439182091
  • 1 month later...
Wanted, set of r33 gtr wheels, tyres aren't a huge concern. I would prefer to buy but I also have a set of 17x9 +10 work meisters I might be willing to swap
Your meisters.... How much ?
1992 R32GTR
T51R SPL 24psi
Apexi power FC
OS Gikken quad plate
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
