Let me know what you need and make an offer. Will match and most likely beat other prices on here.
Bonnet, bar, reo, guards, headlights, indicators, grill - all in excellent condition - $3000
Boot with spoiler
Rear bar
Boot trims
Interior is shabby - ripped seats, tweeter holes in door trims etc.
Shell is complied but has had a hit in the front. Probably not worth fixing but all glass, roof, doors etc are good.
Have stock turbos with zero shaft play
manifolds
Exhaust
Dash
You get the idea. Let me know what you need.
I want to hang onto the engine, ecu, wheels and front brakes at this stage. Everything else available.
Would prefer local buyers as I wouldn't have a clue how to upload fotos, but I can send them.
https://www.sau.com.au/forums/topic/363802-wrecking-r32-gtr-canberra/
The front end panels are black. The rest of the car is bayside blue.
Front bar 550
Bonnet 800
Guards 400 ea
Grill 150
Indicators 150 ea
Headlamps with hid lights 400 pair
Reo bar cut for n1 vents 100
Radiator support panel 150
All the above in a package 3000
Bootlid 200
Gtr spoiler 200
Doors complete 400 ea or 200 ea minus glass and motor etc
Rear bar 150
Tail lights 200 pair
Windshield 200
Rear windshield 200
Door glass 100 ea
1/4 windows 100 ea
Stock turbos zero shaftplay 200 ea
Exhaust manifolds 150 pair
Dump pipes 100 pair
Gearbox 900
Coilovers rears are a little leaky 600
Front seats ripped and drivers doesn't recline 300
Back seat stained 100
Seatbelts 200
Doortrims, have tweeter holes 100 pair
Dash
Cluster
Boss kit
This is a start. Offers welcome. I don't know what all this is worth but everyone is too shy to make offers so I started. Don't like the price make a fair offer.
My postcode is 2913 if you want to sort out postage.
Hey mate was just wondering if you had any rear gtr Hubs that the driive shafts from the diff atttach to?
Have the following items for sale:
R32 GTR rear lsd/diff (pic for reference but is exactly the same)
$150
2 x R32 GTR dashes (1 really good condition with a small lift and one with ok condition with bubble infront of passenger)
$70/$30
Leather shift boot and handbrake
$20 for the Red/Black set
$10 for stock gear shifter
Pair of Recaro seat rails (1 Genuine, 1 not)
$150 for the set (will not separate)
Boot with spoiler
Rear bar
Boot trims
manifolds
Exhaust
Dash
  • 4 weeks later...
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
