This is just a big meet-up open to all
There is no 'cruise' but something may happen on the night after 10pm..
Unsure on that... but i aint planning it.
This along with MAS is taking 3 hours of my day, everyday lol!
DT come on down, more than welcome.
avalonea - that's the whole purpose of this cruise, for interstate people here for the nats.
would be wicked to have you there.
cheers boys - looking like a superb turnout. DONT MISS IT
ash
Hey guys, it was a fantastic meet up, it was really good to rub shoulders with some of the tuning workshops around and also D1 Drivers. Damn they are a cool bunch of people and know how to have a good time. BIG communications gap, but it was a good laugh. The guy with missing teeth was the funniest... whats his name?
Question: what happened with the red r32 that was doing a drift on the straight? Did he get done by the cops or...? Hope he got out of it unscathed.
If anyone wants to contact me from the meet, my number is 0407-311-375, email: [email protected] (remove -nospam-) and i was wearing the cream "75" jumper.
Good meet guys, cops were very good as well...... i just hope they didnt go too hard on Adam.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
