Proudly Presents:
Import Monster SAU-Vic DECA Motorkhana ROUND 2 of 4 of the 2011 DECA CHAMPIONSHIP
When : Saturday 4th June 2011
Where : DECA - Shepparton, 145 Wanganui Road, Shepparton, VIC 3630
Cost : $85
Max Entries : 50 + Reserves
-= PLEASE NOTE =-
The insurer of the event (AASA) has issued supplimentary regulations that require all entrants to wear helmets during all competition. This includes the skidpan and all battles.
This also impacts passengers, as they must also now wear a helmet prior to entering a competition vehicle.
A fire extinguisher is required by all entrants. This is for your own safety.
Please re-read the supplimentary regulations before entering the event.
Entry Form & Supp. Regs. : HERE
FILL OUT FORMS COMPLETELY. INCOMPLETE FORMS WILL NOT GO ONTO ENTRY LIST.
***Also, if you are emailing you entry, please name the attached file after your full name and what page it is. eg. 'Ryan Bell Disclaimer'.
Event Schedule: Event Schedule
Results: Not yet available
All withdrawles will be refunded after the event. Refunds will not be given after 5pm Monday 30th May.
Anyone paying by cheque MUST make the cheque out to Skylines Australia Victoria. Cheques made out to anything else WILL BE REJECTED.
Please support our sponsors : Import Monster Pty. Ltd. Factory 3, 6 Wigan Road Bayswater VIC 3153 (03) 9008 0031
  • Replies 221
Posted Images
ENTRY LIST:
1 IMPORT MONSTER Aaron Klaver
2 IMPORT MONSTER Ash Cosgriff R33 GTR
3 Leon Stapley 180sx
4 Ryan Bell Sileighty
5 Jimmy Wong Liberty
6 Martin Sullivan 200sx
7 David Hurst R32 GTS4
8 Winston Ho Toyota Chaser
9 Ashneel Prasad Toyota Chaser
10 Glynn Matthews WRX
11 Luke Schulze R33 GTST
12 Dinusha Herath
13 Stan Lubinkov Forester
14 Terence Ho R33 GTST
15 Reade Clouston Ford XR4
16 Simon Wilcox Toyota Chaser
17 Jake (Mike) Lowry S14
18 Phil Mak S13
19 Charlie Cheng Mark II
20 Jett Benson Fairmont
21 Mark Homer 944
22 Russell Cunningham R32 GTST
23 Brendan Pryor R33 GTST
24 Joesph Pezzimenti 180SX
25 Kieran Robinson Supra
26 Nghia Nguyen Liberty
27 Harsh Gupta R33 GTR
28 Roman Plotnikov 180SX
29 Joshua Robins Clubman MS8
30 Gerald Tan Supra
31 Bart Kohler R32 GTR
32 John To Mark II
33 Akshay Rajan 911
34 Mario West Evo 8
35 Brent Germain R33 GTST
36 Sanjay Subramanian R33 GTST
37 Jeremy Taylor 200SX
38 Dean Taylor 200SX
39 Byron Scott S13
40 Rhys Solomons R33 GTST
41 John Packham S14
42 Ashley Stacey R33 GTR
43 Sean Power S14
44 Justine Schuller S14
45 Shane Janssen
46 Campbell Shobbrook 180sx
47 Chirs Stacey E30
48 Marcus Stacey E30
49 Chris Taylor
50 James Newton R34 GTT
Reserves:
1
2
3
4
5
6
7
8
9
10
Just first reminder for those entering..(first of prob many)
Competitors must wear non-flammable clothing extended from ankles to neck to wrists. Nylon clothing is not
permitted. Shoes must be closed toe.
this will be strictly enforced. and we will be checking during scrutinizing.
Driver and passenger have to wear long sleeves and pants and be non flammable..turn up in shorts and tshirt and you will be on a mission to kmart prior to racing!!!
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
