  • Replies 110
ahhahaahahh
ok the deal is....
1. the car was purchased like that
2. i dont/ cbf taking it off or even re-sticking it to the right spot...as i know its gona *** with the paint somehow...
3. the number plates as abit bad...but seeing as i brought them 5 years ago it was time to dust them off.....
its a gts....mok GTR sure .....
as raaage said there are lots of ppl that mok their cars up with stickers etc...and pretend to be something they arent.....
flame away
Whilst i was in Canada i saw a GTR bade on.... wait for it.... the END of a T-Wing... but wait, there's more. On a car that looked like it was from the 80's, called a Sirocco or something like that? Look like some sort of Hatch from the 80's or poss early, early 90's. I'm almost 100% it was not a nissan of any type. Hopefully some of u guys know what i'm talking about, not sure if i got the 'Sirocco' spelling right.
Merli u r right, it is a pissa about the placement of the badge, but maybe the original owner thought the GTR badge was too common, so he 'purposely' mis-placed it? :P
also not sure whether the Front GT-R badge is right in the middle of grille either? Looks a bit off set to the right :P maybe my eye's been so thrown out by the rear badge i can't tell with the front one!
That is my GTR with the GTR badge of the bonnet, let me clear some things up
1. Yes I did put the badge on myself
2. It is 100% Center
3. I can do what I like to my car as its what I think that counts, I think it looks good and I have had a few ppl say the same thing.
4. I can put as many GTR Badges on my car and anywhere I want, why you ask?? Because its a REAL GTR not a GTST that wants to be a bloody GTR aka THE OAK.
THE OAK maybe you should do your self a favour and remove your badge or atleast place it in the right spot. And since you wanna be a picky little fella why dont you remove you STICK ON Bonnet Pins too and get the real deal.
Oh man... that badge is a classic!! Looks freaking awesome. :rofl:
S.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
