  • Replies 110
Hmmm I hope this isn't a repost but
Original ad
That badge placement (and the other stickers haphazardly placed over the exterior) actually devaluate the car... what a tool.:slap:
lmao and it's a Silvia :D
Long Comments Powerful Nissan Silvia (Awarded best drift car by Fast Fours)1992 black, auto,2lt., reg Aug 2004, Going overseas, Excellent Sylvia at a bargain price. Features include: full electrics,climate control, power steering, power windows, e/mirrors, digital air-con, power/hold switch, remote central locking, 21-way antitheft system, keyless entry, alarm,engine immobiliser, cd radio,sports exhaust, tint window,HKS, mugen Decals,custom interior,speed warning indicator.
GTR Badge = 25 Hp.
  • 6 months later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
