hey guys this is my first post and i have a few plans,
i want to put a 6 speed gearbox in my gts and need to find one that wont be a pain in the ass with the size and/or fitting
i understand ill need to get an adapter plate made up and tailshaft and info on what gearbox to use and general help would be great thanks,
https://www.sau.com.au/forums/topic/364356-r33-6-speed/
  • Replies 86
and i was thinking twin high flowed rb26 turbo setup
550 cc injectors, tomie poncams, cam gears,
anyone think of anything to build an awesome engine
Im building an rb30/25 (about 40 percent done, engine runs pretty good but gutless still stock n/a ,atm, now its time for the mods.
https://www.sau.com.au/forums/topic/364356-r33-6-speed/#findComment-5813771
Dude i think you will probably find its more bother than its worth.. in my experience these sorts of things tend to turn out costing more than the car itself. Is there a specific reason you wanted to go 6 speed?
what mods have you done to your gts-t, thanks
https://www.sau.com.au/forums/topic/364356-r33-6-speed/#findComment-5813801
what about a r34 gtr box with the transfer box removed (if it's possible) or just with the front drive shaft removed
Same as the 350Z box but with a different Bell housing, so same deal really, eeither cut the transfer case off the GTR box or make a bell housing adapter for the 350Z box...which I belive Mark @ Hills motorsport in Castle Hill were developing a kit do do exactly that.
https://www.sau.com.au/forums/topic/364356-r33-6-speed/#findComment-5813820
Im only starting brother, its pretty stock at the moment- turbo back zorst, coil overs, intake, R34smic and a slight boost increase. I plan on a hiflow turbo, upgraded injectors and front mount soon. I will be happy with around 250rwkw.
Your 25/30 build sounds f**king promising though! I think the whole idea of the 6 speed is great in theory, but probably way too costly to make it worth it. Definitely worth looking around at it though and getting some prices, i always wish my liner had an extra gear on the highway.
https://www.sau.com.au/forums/topic/364356-r33-6-speed/#findComment-5813856
thanks man, down the line when im finished the engine ill probably go all out with the 6 speed gearbox,
but atm ,
im up to getting the mods (in progress) and fitting them, tuning it, work out all the kinks, lay down some 1/4 mile times, hopefully some track runs
and then worry about cruising down the highway in six ,haha, would be sweet though.
cheers.
https://www.sau.com.au/forums/topic/364356-r33-6-speed/#findComment-5813920
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
