Sell the car - but a turbo model.
Then you get the brakes, gearbox and everything else.
It'll cost more to upgrade your bits than it would to actually buy a car and just use what comes standard.
What are you trying to achieve with a 6-speed gearbox anyway?
It'll cost you 5-6x as much, and really offer nothing.
  • Replies 86
thanks man, down the line when im finished the engine ill probably go all out with the 6 speed gearbox,
but atm ,
im up to getting the mods (in progress) and fitting them, tuning it, work out all the kinks, lay down some 1/4 mile times, hopefully some track runs
and then worry about cruising down the highway in six ,haha, would be sweet though.
cheers.
Keep us updated with ya progress man.. and welcome to the forums
f**k why do threads like this end up with ppl giving him so much shit?! Its pretty obvious from his first post he was just after some advice/opinions on the matter.. Sure, heaps of ppl are helping, but he's also getting a bunch of f**kwitts that act like its money outta there pocket and some sort of insult that he wants to do something different.. If you have nothing helpful to say f**k off.
Different is one thing, a gross waste of money is another :)
But ye, not the first "i wanna put a 6-speed" thread, there have been many in the past, and thankfully people realise there is little point and stick with the normal 5 speed.
Also the same for getting a N/A upto a turbo-spec type thing. Easier and cheaper to start from a turbo base.
[/quote
mate im in the process of an engine build,
and i beleive an rb25de head iis better, then the rb25det head when building this sort of thing ,
sure its harder, but its what i want to do, so enough critism mate.
i am asking for info.
Nismoid does have some solid points man, in just about every case its going to be cheaper and easier to start with the turbo model as its base has the better gearbox, diff and brakes as far as im aware. Having said that, i completely agree with your decision to do it your way. With these forums having wrecked turbo models all the time, you can pick up all your parts really cheaply anyway. Plus the plans for the car sound awesome.
well s15 6 speed is a pile of shit when lined up next to rb25 5 speed.... so dont bother looking at this as an option.
s13 never had 6 speed.... so yer i dunno what you meant by that.
With a lot of f**king around you can get a gtr box to work but im slightly confused as to why????
if you can give reasoning for ur want of changing to 6 speed then it may help.
unless u regularly drive down the highway at 160 kmph then what is it needed for?
and if your doing track work unless your thing is a missile you wont need 6th gear i would not imagine (depending on track)
if i was going to contemplate spending this much money doing a 6 speed conversion i would just bite the bullet, borrow some money and put a 6 speed sequential hollinger in my bus hahah
from what i recall, to make a gtr 6 speed work well you would also need the diffs, once again cost is going up for no real gain
as everyone has suggested already through experience and knowledge its much better to stick with the 5 speed
6 speed may not change final drive much anyway, it will primarily fill in gaps, which with the torque that an 30/25 will make is going to be of little benefit, you may even find that on a track with the weight and extra changes you will go slower. But you did say that you were just after advice about which box to use, maybe a Supra box?
thanky you, finally someone understands, its not about performance its about drivability sure the 5 speed is great, but i want a 6 speed, i dont need one i just would like to have one.
started with the n/a so even shitty turbo wrecked parts is a start lol, ive got the engine and drivetrain part going good so far, so the wrecked turbo parts ect turbo brakes ect will be all i need. for the time being until i get into serious stuff like racing, track work ect but right now its basically a sleeper project that isnt a typical sleeper, thanks.
im just contemplating my options ive always wanted a 6 speed not to make my car go faster (cause theres no difference except for the extra gear) just cause i want one, am i being so obscene to want to do it my way?
sorry about the s13 6 speed, some dude informed me it was good, ( to bad theres no such thing) thanks.
Edited by Nathyns r33 gts
yes thanks, ive always liked the supra 6 speed, im not worried about the final drive ratios ( i would've just changed the diff ratios lol) thanks mate
im not after gain though, im after a nice drivable car capably of cruising down the highway (my ratios are f@#%ed im doing 3400 rpm at 100kmph in 5!)
while also capable of some sweet power,
thanks for your input, cheers.
thanks man good to now there are some good guys that are actually interested in my plans and not just try talk me out of it cause they dont like the idea, my car , my plans , my way . cheers mate thanks heaps.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
