Hey guys/gals,
I have a 1996 R33 GTS25-T Manual, and being my 6th Skyline i have grown bored of it and ready for the next car:
I have had a SR20DET s14 Silvia, a 1UZFE Soarer, and every type of Skyline excluding a GTR.
I am starting to feel the need for something less 'boy-racer'
What do you guys think of the 1998-2002 Legacy B4's? I know nothing about them except that they are twin-turbo boxer's and they are extremely good looking cars.
Can anyone tell me anything about how they feel to drive and their reliability? I can't test drive one because car dealer's think a 21 year old just wants to thrash them.
I have attached pictures of my current Skyline and the type of B4's i'm talking about (in Australia i think you call them Liberty? I'm from NZ)
Note: In New Zealand these two cars are roughly the same price on the market.
Cheers for any feedback
Edited by rorz
https://www.sau.com.au/forums/topic/364411-legacy-b4-tt/
It's a very well balanced car - AWD
You might wish to get a thicker RSB with HD links for even better cornering
Engine mods might be limited as many other things need to be changed if upgrading propellers.
Sound system from USA is superb.
https://www.sau.com.au/forums/topic/364411-legacy-b4-tt/#findComment-5814677
Beware the "valley of death". The TT's had a laggy hole between the smaller turbo handing over to the larger one.
This can be fixed by ditching the twin setup and its convoluted piping system and chucking a vf23 on it, then itll go good.
Just find a single turbo unit, you will be much happier.
https://www.sau.com.au/forums/topic/364411-legacy-b4-tt/#findComment-5814885
The b4s are ok. I used to work on them.
There not quicker then a wrx, dont let the twin turbo fool you. It was designed more for better torque then outright power.
Homestly i wouldnt bother. Youll get bored of it pretty quickly.
They are a nice car though. It will be realiable and comfy but thats about it.
https://www.sau.com.au/forums/topic/364411-legacy-b4-tt/#findComment-5815241
Not to mention that if you want a wagon they're very rare, only available as personal imports.
And yes, the lag before the change to the big turbo is pretty woeful. The Legnum, performance wise, is a much nicer car to live with.
https://www.sau.com.au/forums/topic/364411-legacy-b4-tt/#findComment-5815258
not sure what you are talking about with the valley of death (boost) mine is fine. 1st comes in at 1800 swaps at 3800 and pulls hard to the 6800 cut off. I have that drive line in this:
I did trick up the autobox a bit though.
https://www.sau.com.au/forums/topic/364411-legacy-b4-tt/#findComment-5815526
depends.
the early BG5s had the early motor in them with the crap heads. . they swapped in the BH5 to teh WRX style engine and the boxes were geared different. unsure about the toyota ones. I know BG5 and earlier quite well.
https://www.sau.com.au/forums/topic/364411-legacy-b4-tt/#findComment-5815552
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
