This is my current setup on my RB20DET R32GTS-t:
GT2530 turbo
3inch exhaust turbo back
FMIC
14psi w/ bleeder
Pod filter w/ partition & CAI
500HP intank fuel pump
Oil catch can
I currently have a dead stock ECU and my car is running pretty rich (std injectors as well), and i want to know what my best option would be with getting some better management. This is what i want to achieve:
- Disable speed cut
- Disable boost cut (or alter it)
- Optimise A/F ratios for maximum power.
I won't really be modifying my car anymore after this.
I have been looking at getting a chip put in my ECU via Chiptorque. The actual chip apparently will give me what i am after and they will make it to suit my current mods using a dyno. I am looking at around $900 for this all up.
Power FC is another option but seeing as i won't be doing any more mods, i think it would be a waste of money....that's even if i could get hold of one.
Are there any other options that i could explore?
Any help is apprciated, as i don't want to make a decision without a bit of advice.
Scott
https://www.sau.com.au/forums/topic/36448-r32-next-mod-ecu-options/
i want to know too. i've got exactly the same mods plus safc, ebc and rising rate fpr. i'm not a big fan of the chiptorque chips, but i know you can get remaps and tuning done for about $600 elsewhere on the coast or brissy. i'm thinking of getting a FCD, cut wire to remove speed limiter, and safc tune on dyno. alternatively i can get a boost cut, fuel cut and raised rev limit raised chip for $200, then get safc dyno tuned.
Can get ya an Apex Engineering (APEXi's custom dept) Power FC for the RB20DET. Ultra tunable and most shops can do it on the fly.
Or I can give you a book with all the different fuel maps you need, but its in japanese.
If your going to be runnng the HKS 2530, then you may want to consider a bigger AFM. This will add a few $$$ plus make the re-map a little more difficult, though still possible.
Whilst the remap is cheaper, at close to $1000 i would stretch to money to a PFc, you get a great live readout of engine parameters, more flexible tuning albeit with a handcontroller and can be bought at the moment for $1100.
If you ever want to sell the car, then you can sell the PFC, and re-install the std ECU, along with the std turbo setup.
That said im running a re-mapped ECU, and will be getting it tuned again with new cam gears/maybe new cams, but im expecting to only pay about $300-400 all up for the tune
I have never dealt with Chiptorque before. Any reasons why you don't think it's a good idea. PM me if you want. Who else has experience with remapping r32 ecu's around Bris, GC? Since i don't have an safc, i won't be doing what you are thinking of doing, as it will cost me way too much and would be better off going full management. fuel cut defenders and safc's aren't cheap. When are you hitting boost cut/fuel cut? And that $200 chip you speak of, is that one that was remapped in another car to different mods? I was think down this track...but how wrong can you go? Like a remapped ecu on a different 32 with similar mods. But what are my chances of finding one that was setup for 2530...lol
I really don't want to mod the car anymore after this....as the next step would have been cams z32 afm....but where does it come to an end...lol
PowerFC would have been the ultimate option, but it all adds up. Say $1100 for it, 400-500 for hand controller....and then tuning! eeek!
Was your remap done on your cars ECU? How much did you gain from it? And what mods do you have?
Thanks for the help guys.
Scott
erm.. yer generally it ends up ending with a rb25 donk or in my case a rb30 donk.
Whats the power curve like? no dips etc? I've heard of good results by just fitting a fuel cut defender. That one that was in the zoom mag that good defected (James from D1) he made some where up around the 230rwkw mark with a fuel cut defender.
Hi Scott, I can tell what a good tuner can achieve by remapping a standard R32 ECU via an on line chip upgrade. But I can't tell you who is a good chip tuner in bananaland. So I would be wasting my time.
My suggestion would be to find your local chiptorque or fueltronics agent, get a written guarantee of results out of them. Tell them you will tell 100 other R32 owners in Joeterritory how great they are if they do a good job on your car. Then get 20 other guys to ring up and say they are waiting on your results. I will bet you that you get a good tune. An average tuner takes longer, but can still get it right, you just have to make him want to spend the extra time.
If you want I will be one of the 20.
I won't bad mouth Chiptorque, i've just seen some less than impressive improvements/power figures for a fair bit of money that it costs. $600 is about my limit for a remap and tune, you'd have to seriously think about spending the extra for an aftermarket ecu above that. That said, they do have a very good reputation and maybe i just need to talk to some more people with tuning by them.
Someone to talk to would be Matthew Spry (0411 340 033 ). He doesn't get a lot of press because he doesn't work for a workshop, he has his own dyno in Molendinar and only does tuning including a lot of the high powered cars on the coast. Gavin Wood also does ecu remaps now and while they're not cheap, his results always impress. The $200 chip only removes boost/speed/rev limit, its not for fuel and timing maps.
Joel i am running into the 10s with the AFR's. My power curve isn't that exciting as you can imagine. It's running the richest at around 5-500rpm which is where the meat of my power should be.
Thanks for the tip Sydneykid...i'll let you know what i decide. I am just making sure to explore all my options before making the plunge.
Neil, thanks for the contacts. Does this Matt do remapping...and how much rb experience does he have. How does Gavin do remaps without using the aid of rollers?
Cheers,
Scott
I remember at least 2 years ago when GTR-Ben was called GTS4-Ben over on SDU.
he said .. If its running rich pump more boost in to it.. lol. :)
If you arn't looking at any more mods then a fuel cut defender might do the trick, providing its all checked out on a dyno while you pump the boost in to it. Sure it won't give you the perfect power curve but it will make more power providing there is a good amount of fueling head room towards the end of the rev range.
I'm not sure if Matt does remaps. Gavin does his remap tuning on the street and Dyson Rotary's dyno.
I may have an SAFC available in the next week if you're interested? There's also a FCD for sale on here and 1 on boostcruising (see post by pink gt) both at about $50. That would mean only about $370 plus probably 1 hours tuning ($85-125) if you wanted to go that way. I'm think i might have to go a standalone ecu since it looks like i need my loom redone anyway and i wouldn't mind bigger injectors. I think i may have to sell a kidney to afford it though...
go for the power fc there is no need to buy the hand controller if someone else is tuning it. If u aren't gonna b modding more then you will only be paying for tuning once. The only problem is you will need to get it tuned with someone who has the apexi excel software, i'm from melb and dunno QLD places. either that or get the hand controller and tune yourself, but u can't see much of the map resolution, but with apexi excel software you can see the whole map and you will get the best results this way.
Try www.fc-datalogit.co.nz
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
