... V6 and I believe it is stock.
Thanks.
:spank: r34's have an inline six engine stock.
And yes, you could be damaging your engine by driving it with a heavy vibration.You most likely have a misfiring cylinder.
Replace the spark plugs, if that doesn't fix it, take it to a mechanic.
Thanks for actually helping and only mildly ridiculing me.
Clearly I haven't the slightest clue of what i'm talking about.
Didn't know that six cylinders could be configured in a straight line or V shape (duh).
End of story I took it to the a mechanic,
It had contaminted fuel. (Possibly because it was sitting there doing nothing for 6 months before I bought it).
And was misfiring.
They drained and replaced the fuel, replaced the fuel filter and also replaced the spark plugs.
Thanks.
Yeah thanks, the car is fine now.
It might just be in my head but i still feel there is a very slight vibration and a minor loss in performance (maybe 5 to 10%).
Although it's difficult to compare to what is was first like because I can't remember. heh.
Performance should be much better....
Does it sound like a subaru? if so you proberly still have a probelm.
I suggest creating a new post in the maintanence section next time to advoid the ridicule :P
"End of story I took it to the a mechanic,
And was misfiring.
They drained and replaced the fuel, replaced the fuel filter and also replaced the spark plugs."
Hey I'm having the same problem, especially when first starting the car, on full steering lock, and in reverse.
which mechanic did you take it to? (whereabouts are you located even?)
are the vibrations still there?
and how much did it cost you to get it fixed?
thanks mate.
I'm not very good at taking cars to bits; But i'd like to help by telling my experience.
I had an NA 34 and i had terrible problems with its "coil packs"
If:
*you're getting that little yellow "engine malfunction" indicator on the dash
and
* you have already but in 6 brand new spark plugs;
and you are still getting misfiring; it could be the coil packs.
Bad news: a pack of 6 Splitfires (best option) off ebay will set you back around 450 bucks.
Good news (sort of) i have my used (but still working) Nissan coil packs for my car which id sell individually if thats what you'd like.
Well the performance is 40x better than when it had vibration but probably on par with just before the vibration started.
The car remains very quiet and is still running well.
thanks mate.
Hi, I am in Melbourne,
Took it to Sabbadin Automotive,
I no longer have any vibrations,
Cost me $500.
I think they got some second hand coil packs for like $80 to save me some money.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
