It would be around 140kwatw.... Dyno readings don't mean shit though.
My S13 with-
C.E.S twin dump pipe (no cat)
Fujitsubo Power Getter catback
K&N pod
11psi
made 165kwatw at Dyson Rotary dyno. Now that figure can't be true, probably closer to 145
https://www.sau.com.au/forums/topic/36468-what-rwkw/#findComment-729920
depends on how well the dyno is calibrated too.
i know we have this problem in the car audio industry, we tuned a car on a relatively new meter and mic and got it fairly flat. took it to a comp with these settings and it was all over the place, then not to mention that the most db anyone could get was 134, and alot of the cars were 140+db cars. found that they hadn't had it calibrated in years and still haven't
https://www.sau.com.au/forums/topic/36468-what-rwkw/#findComment-730016
my brother had a 97 blacktop 180 that had an S-AFC, profec B BC, a cannon of an exhaust (145DB) and at 13psi it had 150rwkw.... for interest the car also had a nismo diff locker with very soft suspenion(quikoffthe line)...it was a very fast car(eh in a straight line!), it used to kill my s2 R33 which had about 170rwkw
https://www.sau.com.au/forums/topic/36468-what-rwkw/#findComment-730282
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
