I also would love to see some 1 do a direct comparison.
the problem is any decent drop in cam means deleating the VCT. The stock cams are actually extremly good and longer duration cams just make it a dogg in low range.
The real downfall of the stock cams in my point of view is actually the amount of lift not the duration. I would love to see the comparison between standard and standard with the cams welded to suit an extre 1 or 2mm of lift as the only change.
Chris
https://www.sau.com.au/forums/topic/364687-vct-vs-poncam/#findComment-5818814
Enabling VCT requires just a little work. Poncams are getting on for a $1000.
If you have the money do yourself and us a favour.
Run your engine with VCT and the stock cams.
Then install the Poncams and see what difference it makes ( I an mostly interested in the mid range, not the power at max revs).
With the poncams in you can test with the VCT on or off. If it runs better with it off then you can disable it with not very much lost.
If the poncams don't do a lot then you can resell them.
https://www.sau.com.au/forums/topic/364687-vct-vs-poncam/#findComment-5818826
I had considered fitting an RB26 intake cam and getting rid of the VCT but not sure how it will affect my midrange.
I'm not sure if the poncams are VCT capable.. (can somebody confirm?)
Failing all of the above, I was thinking of taking the std RB25 VCT cam and getting it re-ground for higher lift and slightly longer duration. I have some specs from Tighe that I was looking at trying to match.
If only I had free access to a dyno :(
https://www.sau.com.au/forums/topic/364687-vct-vs-poncam/#findComment-5821216
Thanks for clearing that up Craved
TitAN- I understand that the RB26 has solid lifters and the Rb25 ran with hydraulics, but what is the difference in cams to run either?
I know that the hydraulic lifters are a bit more forgiving and quieter but dont like too many revs or they can "pump up" -This is why the RB26 was fitted with solids to allow it to rev harder being a race-bred engine
But...
I still dont see or understand why there would be any difference in cam profiles for hydraulic or solid lifters...
Can somebody in the camshaft game shed any light on this for us??
At present I am using an HKS step 1 exhaust cam from an Rb26 in my RB25 powered R33 track car and doesnt seem to be causing any problems (been fitted and raced for 12 months)
If somebody in WA (Perth or south of) is willing to let me use their dyno for a few hours for a heavily reduced price, I will trial std Rb25 VCT cam and tune Vs Std Rb26 cam in the same engine in the same car...
https://www.sau.com.au/forums/topic/364687-vct-vs-poncam/#findComment-5827644
Hydraulic lifters are subject to this thing called "hydraulic intensity" which limits how quickly the cam can open the valve without "collapsing" the lifter mechanism (which would be detrimental in terms of performance). With a solid lifter, the cam profile can be more aggressive and can accelerate the valve off the seat and open it fully more quickly, resulting in "more area under the curve" (more valve opening during the same period) than is possible with a hydraulic. Because of the difference in ramp rates on the camshafts, in general it's not wise to put a solid lifters cam on hydraulic lifters, and vice versa.
https://www.sau.com.au/forums/topic/364687-vct-vs-poncam/#findComment-5828366
That makes sense TitAN- Thankyou for explaining further!!
urtwhistle- You can do that, but at your own risk. So far my cam is working well, but following zebra's comment damage to cam/ lifters is probable..
I will look at getting a std vct cam re-ground for greater lift, but try retain stock ramp rates
https://www.sau.com.au/forums/topic/364687-vct-vs-poncam/#findComment-5829492
soooo am I reading this correct. I could put a 26 exhaust cam in my neo head????
NEO has solid lifters, so yes you could but i would check the specs of the cams before changing them (unless you mean aftermarket 26 ones)
dont go more than 9mm lift
https://www.sau.com.au/forums/topic/364687-vct-vs-poncam/#findComment-5829924
KiwiRS4T- When you grind a cam for more lift, you are removing material from the base circle, this increase the difference from base cicrle to tip of lobe (increasing lift)
By grinding the base circle down and flattening the top of the lobe, you can gain a small amount of lift and longer duration.
Better springs will help with higher lift cams to prevent the coils binding. May also help with higher revving engines. As I dont plan on revving harder than 7000rpm with the 30 I doubt I'll need upgraded springs.
The bottom end of the 30 is quite strong as is, so I'll save my money maybe just for ARP bolts right through.
For me to get a cam ground is cheap as I am good friends with company owners that do cam grinding :)
Why not more than 9mm?
I am currently running the HKS Rb26 exhaust cam (8.7mm lift) without any issues.. I do understand cam geometry could be an issue with hydraulic intensity as you mentioned before especially with grinding the standard cam down to acquire that amount of lift..
https://www.sau.com.au/forums/topic/364687-vct-vs-poncam/#findComment-5829969
After thinking about this thread I called "southside engine centre" who do some very nice engines and discussed machining the base circles to suit more lift.
The main problem that I never thought of was that due to the NEO and 26 heads having solid lifters would mean reshimming the head with much bigger shims. Which runs a higher risk of spitting a shim out and smashing the cam. They strongly suggested not going this route and fitting an after market cam that didn't require using big shims. That might not be such an issue in a hydraulic head though.
The link below shows that a NEO ex cam would probably be better then a R34 ex cam. It has more lift but only slightly less duration.
http://www.tomei-p.co.jp/_2003web-catalogue/e090_camshaft-specs.html
https://www.sau.com.au/forums/topic/364687-vct-vs-poncam/#findComment-5829978
Thanks for that... geddit now. Regarding bottom end I guess it depends on your power goal. Mine is not forged either - just rings bearings new conrod bolts and an N1 (!!) oil pump. According to RIPS good for mega kw but I will be happy to crack 300 and ecstatic if it will make 330.
https://www.sau.com.au/forums/topic/364687-vct-vs-poncam/#findComment-5831333
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
